Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 02-22-2008, 04:47 PM
CNC1970 is on a distinguished road
Timer switch
Hi ,
I have a cilinder with end switch #83=1 cilinder go left wait until hit switch
but If there is no air I want an alarm as
#84=0
#83=1
WAITUNTIL #59=1:SLEEP 2:LABEL1 AIR TOO LOW;12:EXIT
-----M50
Old 02-22-2008, 06:23 PM
camsoft is on a distinguished road
' The following routine checks to see if a prox switch is hit within 500 ms
' If not then display a message
' Change time 500 ms and I/O relay # as needed
#83=1 ' Engage air cylinder to start move
TIME RESETMS ' set millisecond time counter to zero
LOOP:
TIME MS;\55 ' read how many milliseconds has elapsed
IF \55>500 THEN LABEL1 AIR TOO LOW;12:EXIT
IF #59=0 THEN GOTO :LOOP ' if switch not hit then re-check again
' If made it here then switch was hit within 500 ms
Old 02-22-2008, 06:58 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Hey Camsoft,
I'm just curious. I would have included a SLEEP 0.025 right after the LOOP: line. The way this code is written the loop will run many 10000s of times in the time it takes to make the cylinder prox switch. My concern is this could bring the 'puter to its knees and affect something else that might be going on in inputio, limitio, or elsewhere. Sleeping for a few miliseconds really frees up computer resources. Is this at all necessary?
Karl
Old 02-25-2008, 10:06 AM
Karl,
Putting a SLEEP in there is okay for the reason you mentioned but if you think about it, it maybe sleeping when the I/O switch is hit. If the relay was only on/off briefly it may miss it.
Tech Support
CamSoft Corp.
951-674-8100
support@camsoftcorp.com
New Machine Build- CNC First timer, a little help? TheMobster DIY-CNC Router Table Machines 18 06-17-2009 11:41 PM
V21 first timer mmachining BobCad-Cam 12 07-10-2007 05:36 AM
First timer jpitty DIY-CNC Router Table Machines 2 02-20-2007 10:38 PM
Timer.fil How much is to much ? murphy625 CamSoft Products 10 04-04-2005 03:32 PM
