| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
| Hi, This is the code LOADING \4 IF\4=0THENEXIT TIME ON;\4 \4={\4*60} :LOOP TIME ON;\55 \55={\55*60} IF{\55-\4}<ITHENGOTO :LOOP -----G4 I see in the book G04 L# I try everything G04 L100,G4 L100,G4I100 but nothing works I want to see the RPM from my spindle I have an encoder from 500 I try this but I see always strange values -0.59 It doesn't change like 100,200,900 from my Galil card I can see he is reading this encoder #50=1 'START MOTOR SPINDLE LEFT LIGHT 4;ON GETRPM 8;\550 DISPLAY5 \550 -----M3 where is this calculate \74 DISPLAY4 {f*(\73/100)} DISPLAY5 {s*(\74/100)} GO x;y;z;u;a;b;c Thanks |
| The correct command is: TIMER ON What are the contents of your timer.fil? Here is mine, giving spindle rpm and a current feedrate update: ~@~TIMER.FIL GETRPM 3;\57 ISPLAY5 \57 DISPLAY4 {\273*f} The logic that you wish to have the timer execute needs to be written within the timer.fil
| CNC1970 'g4 dwell 'program example ~ G4 L2 SLEEP l 'lower case L -----G4 'display programmed spindle rpm DISPLAY5 {s*(\74/100)} 'display spindle rpm from encoder SPINDLERPM \550 DISPLAY5 \550 -----M3 \74 is calculated internally when set into parameter in CNCSETUP ~ Analog Controls ~ SPEED (variable) ~ \74 PM your .CBK file to review for CNCSETUP parameter settings. Del |
| n174k has your G4 code spot on. It takes a bit of effort to get your spindle RPM readout working. <I'm assuming you have spindle speed control on an aixs>First run TEST SPINDLE to get the three parameters to put in your startup.ini. I not with my manuals so I don't remember the exact names of these. Then you have to set up your speed pot. Read on this, instructions vary by how you set this up and whether you have a phisical pot, an on screen slider, none, speed mulitplier etc. Finally, your M3 and M4 code will have to include the SPINFORWARD command. <My M3 and M4 turns on different contacts to start spindle, then issue SPINFORWARD> I like to use TIMER.FIL to read the spindle rpm every second or so and then put the rpm on the display. Several ways to do this. Karl |
