Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 07-23-2007, 09:18 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Proper Opto Isolation
I asked a question about wiring a galil 1900 board on the Galil forum and I'm puzzled by the caution statement at the end of the responce
http://www.galilmc.com/cgi-bin/ubb/u...c;f=1;t=000408
I'll explain my wiring concept. I use supply 24 volt DC to all input switches whever posssilbe. Then from the switch to the Opto input. From the other connection on the opto input, a wire is run to the dc common terminal block. Most switches are wired NC.
Does this have a weakness in opto isolation?
Karl
PCB Trace Isolation - Minimum Track and Isolation ahoodlum General Electronics Discussion 11 09-25-2006 11:02 PM
PCB Isolation Routing experiences 10bulls General Electronics Discussion 26 12-06-2005 04:56 AM
Opto isolation on the Gecko G320? jguillen08 Gecko Drives 1 09-30-2005 08:05 PM
Electrical Isolation? (p.sup.) FLUTE HEAD General Electronics Discussion 4 08-24-2004 01:55 PM
Parallel Port Opto Isolation ??? GrahamIT General Electronics Discussion 9 07-17-2004 08:57 AM
