| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
While using CamSoft's GOI I read in the manual on page 1-19 under MCODE.FIL file. "The theory is simple. When the program reads a line of code that contains an M code in your program, then it simply performs the logic steps sequentially that you have listed in the MCODE.FIL file." Well after not being able to execute an M Code from my program I call CamSoft. They tell me that you CAN NOT execute any of the 199 user defined M Codes from the program. When I questioned them about the explanation in the manual their comment was to me "It must be a typo". I know this is CamSoft's lower end product but this is a misleading statment and not a typo! HillBilly |
| HillBilly, I don't follow what is happening. What level of their software are you using?
| Al, This is real straight forward. I can define a M Code, assign it to a button, push the button and it will execute. When I try issuing this code in a program it is ignored. Maybe I'm lazy but after I define how to do something in complete detail, like walk, I would rather say walk then go through the one foot in front of the other ect., every time I need to walk. If anyone has a ideal how to call a routine within the user program on the GOI I would like to here! HillBilly |
| Are you trying to execute axis motion from Mcodes? No workee. Use Gcodes or macros.
| To All, GIO is CamSoft's general automation software. I am using it with a digital I/O board only. There are no G Codes with GIO but there are 199 user defined M Codes. The only problem is you can only execute them by assigning them to a button! Any Ideals? |
| HB, What if you write a macro in the macro.fil as a process and embed the name of it in the M code of your choice in the mcode.fil. This way you could call the M code from a screen button or as the process name in your program. Would this work????? Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Al, Yes that worked great and made life alot easier! When I talked to tech support they said I couldn't call a macro from the user program either. Thanks to your suggestion I decided to try. Writing [M?] is just as easy as writing M? to me. Thanks again HillBilly |
| Here's a thumbs up for you Al. Way to go.
