Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 12-09-2003, 11:49 AM
squarewave is on a distinguished road
Multiple Axes Readouts
Is there a way to display multiple coordinate systems at the same time? For instance "Distance to Go" and "Absolute"?
Thanks for any hints!
Old 12-09-2003, 01:48 PM
HuFlungDung's Avatar
Moderator
It would be a nice feature to see added, wouldn't it? You can switch the display modes now by creating an M function for it, but you likely are already doing that.
Old 12-12-2003, 02:02 PM
camsoft is on a distinguished road
Steve,
Make a button that the runs the Macro [READOUT TOGGLE]
It toggles up to 8 axes position readouts between these 4 modes.
INCREMENTAL MODE
ABSOLUTE MODE
DISTANCE TO GO
RELATIVE TO MACHINE ZERO
Also use the PgDn keys to rotate between the G code display window and position readouts then press PgUp to blow up the readouts or G code window to full screen with large fonts.
Tech Support
CamSoft Corp.
(909) 674-8100
support@camsoftcorp.com
www.cnccontrols.com
How do I gang axes? X X Y Z not working. Javelin276 LinuxCNC (formerly EMC2) 4 03-06-2005 10:32 PM
Unrestrained axes chuckknigh DIY-CNC Router Table Machines 5 09-13-2004 02:52 PM
can anyone explane all 8 axes? zander1 General CAM Discussion 11 07-08-2004 11:50 AM
Multiple Bit Hobby CNC Router, Possible? Sanghera DIY-CNC Router Table Machines 27 04-17-2004 01:20 AM
Multiple axis questions ynneb DIY-CNC Router Table Machines 1 03-03-2004 09:52 AM
