Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 05-25-2006, 08:17 AM
hugo cuvilliez is on a distinguished road
camsoft and yaskawa axis controler
Hello,
I'd like to know if I can easily drive yaskawa 4axis controler(smc-2000) with camsoft.
I heard it was a galil card inside?Wich one?Can i take it out and use it in my PC.
I need an answer fast!!!
Thank you.
Old 05-25-2006, 08:29 AM
Al_The_Man's Avatar
The Galil card is the hardware part of the Camsoft system, and it would depend on what type of Signal the Yaskawa drive accepts and wether it is compatible with the Galil card.
The most common are ±10v dc analogue.
The Galil cards are fitted in a PC slot, later type being PCI, you can either purchase your own or buy it with the Camsoft system.
If you want details of the card, see the www.Galilmc site.
Old 05-25-2006, 08:36 AM
Al_The_Man's Avatar
I think I misunderstood your first post, I remember now the SMC-2000 is a stand-alone control system with a repackaged Galil card inside, I assume your question is can you use the card in a PC, I would think so if it is a standard PC slot configuration.
Old 05-25-2006, 05:02 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Does it look about like this Galil DMC-2000 contoller?
http://galilmc.com/products/optima/dmc2000.html
I see it uses USB communication. In Camsoft's manual, they mention use of ethernet controllers not being as good as ones that go in a PC's slot, slower and more prone to EMF noise. But, appernetly acceptable to use with these limitations. I didn't see any mention of USB controllers.
Karl
