Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 05-02-2006, 04:47 PM
n174k is on a distinguished road
CamSoft Threading on Lathe
We have developed an interface module that uses the spindle encoder marker pulse to trigger the start of each threading pass. It utilizes existing 12/24 volt power to trigger an auxiliary input module. Anyone interested can private message for more info.
D
Old 03-22-2007, 07:44 AM
Karl_T's Avatar
Karl_T is on a distinguished road
If somebody else goes this route, you should get a high speed Opto 22 input
http://www.opto22.com/site/pr_detail...71003,,,26,50&
For the DIY type, the circuit you need depends on whether you have a single or differential encoder. A pic and schematic of the single end unit I had built is attached, just two parts a 10Kohm resistor and a MOSFET transistor.
I may need a differential unit someday. My friend drew up the needed schematic. (attached) The data sheet for the quad diff. transceiver:
http://focus.ti.com/lit/ds/symlink/am26c32.pdf
Karl
ID:	34072   Click image for larger version
ID:	34073   Click image for larger version
Old 11-04-2008, 10:23 PM
davesnd's Avatar
davesnd is on a distinguished road
So you wouldn't use a VIRTINDEX command to time the start of each pass using this hardware? Am I understanding correctly? You would just be able to read an input and use a waituntil to start each pass?
Old 11-05-2008, 06:27 AM
Karl_T's Avatar
Its slightly better to use WAITAUXIO. Faster reaction times for better thread results.
Yes, the VIRTINDEX is no longer used.
The schematic for the differential unit in my post #2 in this thread looks complex. It's just a $2.50 IC that you get from digikey.
Karl
