Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 02-23-2006, 10:40 PM
plateroomred is on a distinguished road
jogging in different modes
Does anyone know why my axis moves in different directions when in different modes. An example would be when using cnc lite in the jog single axis mode with a joystick, when I push the joystick forward the Z axis goes up but when in incremental mode it goes down. This makes it awfully hard to do tool touch offs. It must be in my cbk file but where?
Plateroomred
Old 02-24-2006, 07:34 AM
Karl_T's Avatar
Karl_T is on a distinguished road
We'd have to see your .cbk to know for sure. Most likely, there will be logic in your inputio.fil that looks at your mode selector switch and calls a macro in macro.fil. In that macro, I'd look for logic that checks for which mode. I'll further guess that the variable flag found in G90 and G91 would be used here. In a lot of .cbks its \774.
You may also want to look at the input#s for the jog buttons in inputio.fil.
Hope this helps.
Karl
Old 02-24-2006, 06:29 PM
Mr.Anderson is on a distinguished road
I believe you said the joystick (USB, Correct?). If this is a USB device then look at the JOYSTICK.FIL file or restore CamSofts default joy stick file if you have modified yours then the original will have the correct code to use.
