| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
| I want to add a plasma torch and torch height controller to the oxy fuel gantry . It is a retrofitted ESAB PUMA that came out of a steel mill in Canada. CAM SOFT PRO, with XP. It has 3 ESAB torch carriers/height controlers for oxy fuel torches. all it has now is a small DC motor to adjust the torch up and down using a DC box and a joy stick. I need something higher speed to turn the Acme rod that would act like a Z axis with out having to buy a new Galil card with aditional axis, I would like to machine a plate on roller guides and a micro switch to mount the plasma torch to and then have some sort of program or macro to move the torch to the surface of metal to be cut, when the torch starts to ride up on the roller plate as the torch is lowering down, it will break the limit switch. This will be Z zero. raise the torch to the corect pierce height, dwell for pierce and then take over voltage adjustment until the cut is finished, and then raise for clearance, Is this just a dream or a bad nightmare? Thanks The Farmer |
| The gantry now has servo motors on the X and Y axis. Each side of the X axis gantry move together, X master and X slave using 2 axis spots on the Galil card. Y axis is only 1 servo motor. my question is can CAM SOFT move a stepper motor on the torch height control with out having to go through a Galil axis. or what would be the best way to control the torch up and down to cut across corugated sheet metal at 50 to 100 IPM. It gets better. My wife wants to get into the metal art business and use the CNC gantry torch when it is not doing real work. Something about togetherness and comunication, since I live in the shop. Thanks The Farmer |
| I don't see how you could do this without a Galil axis. Why don't you shop eBay for a card? They go for 1/4 of new. Then sell the one you surplussed. Shouldn't cost more than $200 to upgrade. Only buy from somebody that promises no DOA. Sounds like you'll be using Camsoft to do the torch height control algorithym. The torch voltage will have some nasty spikes and noise that will trash your galil card. You'll need a good isolation DC voltage transducer with some inductance to filter out high frequency noise. I'm no marriage counseler, but a wife in the shop is like a man in the kitchen. Don't work at my house. Karl |
NEW OHIO SEMITRONICS DC VOLTAGE TRANSDUCER VTH-008EY01 | eBay just what you need to read torch voltage into a galil card. Use a 500 ohm resistor to convert 4-20 mAmp to 0-10 volt. Karl |
| Stepper motors or ac servo motors? | JIM at ATG | Commercial CNC Wood Routers | 7 | 06-13-2011 03:10 PM |
| Need Help!- Stepper Motors | haku | Open Source CNC Machine Designs | 9 | 10-26-2010 05:00 PM |
| Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China | Ling | Product Announcements & Manufacturer News | 2 | 07-12-2009 04:10 AM |
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
| stepper motors or servo motors? | jprobst | Torchmate | 3 | 07-13-2007 05:37 PM |
