Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 05-12-2011, 05:29 PM
Montabelli is on a distinguished road
cam soft-galil-sureservo
Any one out there recently hook up a sure servo with a galil 18x2 and cam soft? I think I am loosing what is left of my feeble mind. I know the encoders are working , the camsoft tuning will run the motors, but I can't get controled motion, the galil tuning software isn't giving me any errors, but I can't get the motors to move from the command line.
I think there must be some thing I missed in the 900 pages of manuals
The motors are sure servo low inertia 400 w motors with the corresponding amps
Old 05-12-2011, 05:48 PM
Al_The_Man's Avatar
How are trying to command the move?
have you tried a Galil native command through the Galil terminal program, if the tuning program runs the drive then it cannot be much?
You have encoder feedback to Galil I assume?
Old 05-12-2011, 06:19 PM
n174k is on a distinguished road
Montabelli,
PM a copy of your .cbk and any electrical drawings of your electrical connections between the ICM module and the SureServ drives.
I have done several of the SureServo installations with great success.
Del
Old 05-12-2011, 08:34 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Del will likely fix you right up.
One thing I do in this situation is go to diagnostics and click the "why is it not moving" button.
I also like to check check things out using only the Galil smart terminal.
Karl
Old 05-16-2011, 10:40 AM
sorry I'm so slow, I have been tying to sort out the galil commands, run my business and build my wife a new kitchen.
I bought the galil software, scope etc. , I have the motors set up in torque mode, I put the 1822 board in a different computer and am running it with the galil terminal as it is supposed to tune better than cam soft. I have shut off the auto tune in the sure amps as I suspect it is not the best to have two auto systems compensating for each other.
so far the only thing I seem to have accomplished is if I try and turn one of the motors by hand, it resists and the scope goes nuts, as expected.
the setup is for a two axis machine ( hotwire). the motors are wired as follows mocmdx to torque in on the ziplink card, signal grnd x to grnd. ampenx to di1 on zip link set to no showing +5 v and enable servo di18 is also set to nc is showing +5 v. the encoder wiring is not an issue, as both seem to work.
y is wired the same way, the setup is not in a machine yet so no limit switches are wired.
every thing is running ttl now, I have +5v showing on all di inputs on the zip link I have all the di settings disabled except
there is no motion from the autotune on the galil program, the only motion I have been able to induce is from the camsoft auto tune and I get an overflow error on that . I can run a test tune fro the camsoft and pass the test, but can't get a jog to complete.
since the camsoft factor is not in play at present, I must have something screwed up in the settings. or the wiring
Old 05-16-2011, 11:55 AM
Al_The_Man's Avatar
I have never used Sureservo, but as they will also operate as a stand alone servo controller, I would think the answer is in the drive set up to allow the drive to act as a non-intelligent drive would so the Galil has total control?
Does the manual cover this?
Old 05-16-2011, 12:02 PM
camsoft is on a distinguished road
If the Sure Servo amp drives and motors were purchased from us or through one of our dealers, there would be a separate pamphlet provided that covers these particular model numbers. Sure Servo is one of many brands we offer and there are several model sizes and connector options so be careful the documentation matches.
Tech Support
CamSoft Corp.
support@camsoftcorp.com
PH 951-674-8100
Fax 951-674-3110
PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
Old 05-16-2011, 12:47 PM
Karl_T's Avatar
OK you're stuck. Happens to me all the time. Take a break, back up and restart from the beginning.
read the heck out of the sure servo manuals to find how to set them up in dumb mode so that Galil controls everything.
Next. I'd get the Galil install manuals and follow their install instructions.
Then, I'd check it against the Camsoft servo installation wiring. They've got a great wiring diagram.
I would stick with Galil only till you got the servos moving. I assume you got WSKD or Galil tools. Follow their "getting started" procedure to first check encoders, then polarity, then sevo tune.
Karl
Old 05-25-2011, 10:21 AM
Man have I been having fun. I reversed the polarity of the encoders and that seems to have solved one of my problems, I am currently of the opinion that I have a problem with one sure servo amp. I can get controlled motion trough one amp and not the other when I swap the zip cable from the zip card to the amp the problem stays with the same motor since the channel with the problem changes it must be the amp. if I switch the motor the problem stays with the amp.
I had tried step and direction as well but that experiment went no where either. now I'm back to torque. I think maybe I'll get this under control some day.
Old 05-27-2011, 01:24 PM
new amp came in today,for the first time controlled motion from bot motors at the same time and no related hair loss. I think I'm over the hump.
Need Help!- Driving a sureservo with Step+Direction AKFALAR Servo Motors and Drives 3 11-16-2008 07:49 PM
Sureservo with Mach3 Mike Boar Controller & Computer Solutions 0 07-15-2008 03:56 PM
Sureservo A/C drives to replace old Baumuller Bap Servo Motors and Drives 1 05-16-2007 10:25 AM
Sureservo A/C drives to replace old Baumuller Bap Servo Motors and Drives 0 05-16-2007 09:15 AM
automation direct sureservo howling60 Servo Motors and Drives 0 06-09-2006 08:26 AM
