How about eBay? I see about 30 offers right now.
opto22, opto 22 g4pb16t items - Get great deals on Electrical Test Equipment items on eBay.com!
Be careful, several have 24 volt logic optos - you can't use those, but the board is OK
karl
You should have no problem with using the 24v in - 5v logic out into the ICM breakout, I have never had a problem using them?
karl
It seems a bit of a waste to use outboard 5v supply for the Opto logic.
The PC power supplies 5v is usually rated fairly high.
On a 16 module board, even if all were populated as logic inputs the current draw should be less than 20ma.
So heres what it is.
I ordered the 16t and will be using G4IDC5 inputs.
Hopefully the board gets here by the weekend with the holiday and all so I can slap it together and give her a whirl.
Guys,
Everything has been wired up and ready to go but we have been waiting on these fuses to get here from the UK. I found every wire I was looking for including all the commons. Once these fuses get here I am gonna fire her up and I will post my results. At that point I may need to start a new thread for help with writing code for the turret, coolant, chuck, and tailstock which are going into the g4 optos. Im gonna read the book and see if I can teach myself first.
