Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 10-19-2010, 07:53 PM
Farmers Machine is on a distinguished road
Cool Feed Back
Baldor said that the only way their servo drive could run the stainless steel servo motor was with feed back hooked directly to the drive. most of their drives read resolvers but He said that they also will simulate an encoder for feed back to the Galil card. Is this an OK way to run a servo or should I look at Servo Dynamics for a servo drive which will read an encoder?
Thank You
The Farmer
Old 10-19-2010, 07:59 PM
Al_The_Man's Avatar
With Galil you do not necessarily need intelligent drives, AMC, Copley Controls & Aerotech for example can be used, but the likes of Baldor that require the drive feedback, in your case, resolver, they invariably will output a psuedo differential encoder type output which can be used by the likes of Galil for feedback to the controller.
Often the resolution can be programmed also.
new to sit. I would like some feed back on these machines cmmi General Metal Working Machines 0 03-07-2008 09:06 AM
Hurco 5M Need feed Back Please roadbyte HURCO 0 03-25-2007 05:10 PM
Lathe work feed back Kool Parts Machinist Feedback 0 09-27-2006 08:30 AM
Give feed back CNCadmin Machinist Feedback 0 09-22-2005 10:42 AM
