Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 03-26-2010, 09:50 AM
Tom Curran's Avatar
Tom Curran is on a distinguished road
Warning! Z axis forward!
I am running CNC Lite in a vertical mill, and every time I try to run a new program, I get 'Z axis forward' and the drives quit. What am I doing wrong?
I ran some older programs, and they work. But the newer program WILL NOT. I went thru and eliminated what I thought might be problems, but I am completely confused.
Tom
Just so you know, my spindle upper limit is 5.5" and the lower limit is 0"
I suspect this may have something to do with the problem.
Here is the beginning of a program that RUNS:
N10 T5 M6
N20 G90 S1500 M3
N30 G0 X-6.5 Y.2125 Z.1 M8
N40 G1 Z-.375
N50 G1 X-6.0899 F5.
N60 G3 X-5.003 Y-.0758 I1.4335 J3.2117
N70 G1 Y-.2145
N80 X-4.931
N90 Y-.8575
N100 X-4.214
N110 Y-.2145
N120 X-4.142
N130 Y-.0758
N140 G3 X-3.0551 Y.2125 I-.3466 J3.4999
N150 G1 X-1.5174
N160 G3 X-.4305 Y-.0758 I1.4335 J3.2117
etc.
Here is one that will NOT run:
N10 T1 M6
N20 G17 G80 G40
N40 S1000 M3
N50 G90 G0 X0. Y-.1 M8
N60 Z.1 (Machine drives quit right here)
N70 G1 Z-.028 F5.
N80 G1 Y1.01
N90 G0Z.1
N100 Y-.1
N110 Z.072
N120 G1 Z-.056
N130 G1 Y1.01
N140 G0 Z.1
N150 Y-.1
N160 Z.044
N170 G1 Z-.084
http://tcurran.com/
Old 03-27-2010, 11:05 PM
69owb is on a distinguished road
Sometimes the control doesn't like it if you don't have G00 or a G01 in front of your X,Y,or Z position
Old 03-28-2010, 05:28 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Originally Posted by Tom Curran View Post
I am running CNC Lite in a vertical mill, and every time I try to run a new program, I get 'Z axis forward' and the drives quit. What am I doing wrong?...
You got me scratching my head... Is this some window that pops with the warning? or a message in the gcode window?
"Z axis forward" would be a limit switch normally, but I doubt we're looking at that based on your description. Just to make sure, you don't have soft limits set up do you?
Comparing the two programs I see the trouble is caused at a small G0 move in Z that you don't have in the other program. Like any issue, you got to narrow things down to isolate the problem.
Look at these things and maybe ask Camsoft tech. support.
Karl
Old 03-28-2010, 10:12 AM
Tom Curran's Avatar
I'll try the G0 in front of the Z move. That may very well be it.
Thanks for the suggestions.
Tom
http://tcurran.com/
Old 04-01-2010, 08:29 PM
Tom Curran's Avatar
Just as an update, I have my tech guy here today, and he got the software limits set up properly on my Z.
STill had touble with my Z axis.
So I sent a copy of the program to Camsoft Tech support. They advised me to put a Z code in the line N50. worked like a charm.
What I had:
What I changed it to:
N50 G90 G0 X0. Y-.1 Z1. M8
http://tcurran.com/
Old 04-02-2010, 06:15 AM
Karl_T's Avatar
Ya sure, Those guys at Casoft are smart. This makes sence. z is a variable in your gcode. When you don't specify it and make a G0 (or other) move, it will go to the z value. Only gets you on the first move of the program. Or, right after a tool change.
Karl
Feed-Forward setting Larken Viper Servo drives 0 04-09-2009 11:03 PM
Problem- Z axis works and then goes up to limit with no warning carbidecraters HURCO 4 06-26-2008 09:28 AM
Need Help!- Can I fast forward to a point in my program? Doubleddaved Haas Mills 15 03-19-2008 07:32 AM
Forward Controls raceshop General Metalwork Discussion 5 01-05-2007 10:48 AM
Can bad forward/reverse toggle cause motor not to spin? ZipSnipe General Electronics Discussion 16 06-03-2006 08:45 AM
