Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 02-28-2010, 01:26 AM
capsteve is on a distinguished road
mastercam posts for camsoft
has anyone figured out which mastercam post processor works best in cnc lite???
i thought the standard basic fanuc was the post to use.
if i set the arc parameter to 2 in the setup menu and use i and j with r in the arcs, it seems to work ok but
as soon as any helical cuts are made in the z axis the controller locks up with an error.
i've got a favorite post that i use in mastercam that works in haas , a mach 3 controlled mill, heindenhain, and our fanuc without issue.
this same post also kicks errors in camsoft..
i must be missing something (i'm feeling pretty stupid)
steve
Old 02-28-2010, 06:22 AM
Karl_T's Avatar
Karl_T is on a distinguished road
My son is the mastercam programmer, so I'm only repeating here. He started with a Fanuc 6M post and made a few changes. In the case of arcs, I really like absolute I and J. This is an option in Mcam. The post for my lathe uses R.
I've never got an Mcam post to run without a couple minor edits. I strip off the junk at the front of the Gcode. And have to change the lines with a T in them. For example Mcam says T1 to go to tool 1. I need M6 T0101.
I'd suggest working out your arc issue with hand coded Gcodes.
Set arc to absolute I J
Try this
G00 X1 Y0
G02 X1 Y0 I0 J0
you should get a circle.
G00 X1 Y0 Z0
G02 X1 Y0 Z0.1 I0 J0
Get a helix?
Karl
Now try
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nachman
MasterCam 5 axis Posts (not free) MrMagooo Post Processors for MC 8 11-13-2009 03:52 PM
Need Help!- Mastercam posts on Mazak tds11223 Mazak, Mitsubishi, Mazatrol 9 11-12-2009 09:00 PM
Editing MasterCam Posts MetalMolder Post Processor Files 8 10-31-2009 01:28 AM
Mastercam X2 Posts nerfman Post Processors for MC 11 07-09-2008 09:47 PM
BobCAD posts vs. Mastercam posts justCNCit BobCad-Cam 124 08-16-2006 02:17 PM
