Program Looping
Results 1 to 8 of 8
Thread: Program Looping
    May 2007
    Default Program Looping
    I'm trying to get my programs to either repeat x amount of times and/or loop continuously. I'm using a CamSoft Pro unit that controls an X-Y table. Reading the GCode programming.rtf file I was given for reference, it has M97 as being used for jumping and goto line numbers. Here's what I tried:
    N00 G20 G91
    N10 G01 X0.1 Y0.1 F30
    N20 M97 N10
    That didn't work. Any ideas on repeating program lines and continuous loops?
    Member Karl_T's Avatar
    Mar 2004
    Dassel.MN
    Change your line to M97 P10
    Here's clip from "Search for Solutions"
    If you look at M97 you will see JUMP. This way instead of the machine operator using CamSoft logic they use M97 like this:
    M97 P100
    This is the same as JUMP N100. The reason you use P instead of N in the Default.CBK is because the logic in M97 uses the lowercase p character as the line number to jump to, much like M98 uses P, also to follow industry standards. However, if you want to change this to use N instead, you could write JUMP Nn
    May 2007
    Excellent tip Karl. Adding the P instead of the N did the trick.
    I got a slight lag where the motors hesitated once it got to the end of my program, then looped. I removed the hesitation with a G08 which is spline smoothing on I discovered, but now the only way to stop my program is with E-STOP. Is that normal with the G08 command?
    Mar 2004
    Dassel.MN
    I've never needed G08. Its been a LONG time but I do remember working with other parameters to get smooth jerk free cuts. Investigate commands like BLEND TOLERANCE, others. Use Search for Solutions on words like jerk, rough, etc. I know there's a lot on this subject in there.
    The G08 command issues the SMOOTH command. As it dumps commands way ahead to the motion card, I can see where you could have trouble with an endless loop G code program. Probably not a good practice to program this way.
    Karl
    May 2007
    I'll do as you suggest by searching with the keywords and checking how the BLEND TOLERANCE works.
    I do need the non-stop program to send my rotary fixtures turning without the need of wondering if my program and fixture will stop turning soon. It's also necessary to continue my movement from where I left off instead of restarting the program.
    Mar 2004
    Dassel.MN
    Do you have "Feed Hold" and "Cycle Start" buttons connected directly to inputs? Me thinks you'll need this.
    Sounds like you have an unusual application. I'd talk to Rueben and Earnie (Camsoft Techs.) after you've read up on the subject.
    Karl
  7. #7
    Member HuFlungDung's Avatar
    Mar 2003
    The SMOOTH ON command should only be issued at the start of a continuous unbroken chain of entities (on the same line as a G1). Then, a SMOOTH OFF command must be issued concurrently with the last entity in that chain.
    No rapid movements should be incorporated within the chain of entities.
    I have no idea how one could incorporate such smoothing gcodes within a standard CAM program, so I usually just hand edit the program, find the finishing pass, and insert the gcodes that call SMOOTH ON and SMOOTH OFF myself.
  8. #8
    Mar 2004
    Dassel.MN
    Didn't hear back from Bohemund, so he may have already solved the issue.
    As I understand, the need is to turn a rotary fixture on and leave it run. Needs to be able to stop/start rotation.
    I think I'd write a custom Gcode that contains:
    COMMAND JG ,,{speed value} <note this would be axis3>
    COMMAND BG
    This would start that axis rotating. You'd then need inputs that would enter COMMAND ST to stop rotation and COMMAND BG to restart rotation
    There may be reasons this won't work, need to know more about application needs.
    Karl
Program Looping
Program Looping
