Need Help! Camsoft & Bobcad - problem with arcs - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Camsoft & Bobcad - problem with arcs
  1. #21
    Oct 2003
    Pompano Beach FL
    Ok found out Bobcad does not play well with arcs = 0 so I am using arcs = 1
    I cleaned up the artwork a bit and made 2 programs with the same geometry, one for the Camsoft and one for my Fadal CNC 88. The Fadal runs it fine. Does that help figure out the problem? I have to believe it is something simple I am missing.
    I know, why don't I just used the Fadal? The material is really too big to fit the machine without taking the ends panels off, even though it looks like I will do that. And I just spent a week mounting a 24,000 RPM spindle on my Camsoft/Bridgeport so I could do this job.
    Here is a section of offending code
    N330G03X-4.537Y-.4361I-.2388J.184
    N331G03X-4.5267Y-.3674I-.2353J.0706
    N332G00Z.1
    N333(JOB 1 CONTOUR)
    N334(FEATURE PROFILE)
    N335G90X-3.8683Y-.787
    N336G01Z-.015F15.
    N337Y.6855
    N338X-3.8411Y.6999
    N339G03X-3.7937Y.6699I.6676J1.0049
    N340G03X-3.7427Y.6421I.3603J.6012
    N341G03X-3.6818Y.6175I.1999J.4066
    N342G03X-3.6183Y.604I.0972J.3014
    Marc
  2. #22
    Feb 2012
    Boynton Beach, FL
    Quote Originally Posted by mbam View Post
    If you are truly running the exact same code on two different machines and one runs it and the other does not, then logically you can't say it's bad code. It's just that your bridgeport/camsoft machine doesn't like it.
    Again, I have seen these issues on and off over the years. Unfortunately they don't always resolve. I've actually seen motion hardware be ultimately identified as the root cause for interpolation errors of this sort.
    Try XYR arcs as a last resort. I've also seen a linear shift in coordinate system resolve this type of problem. also try changing the arc radii by a few thousands. I've seen that work also.
  3. #23
    Moderator
    Apr 2003
    The math isn't perfect but we can get it to run here too.
    It appears that this is going to take deeper investigation. Please contact us with either your company name or serial number and the version number you're using. We will also need a current backup of your CBK file send to:
    support@camsoftcorp.com
    Tech Support
    CamSoft Corp.
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
  4. #24
    Oct 2003
    Pompano Beach FL
    Turns out it was a problem with my CBK.
    I still don't know exactly what it was but I started from scratch with a default CBK and copied over the .fil sections one by one.
    Marc
  5. #25
    Aug 2015
    Default Re: Camsoft & Bobcad - problem with arcs
    im making a fixture for some parts im making and the program simulates fine but when i put it on the prototrak mill itll cut the first cut depth using side roughing then on the second cut depth it stops and says the math is bad and cant find arc centers. ive been working on this problem all day.
  6. #26
    Member Karl_T's Avatar
    Mar 2004
    Dassel.MN
    Are you using a Prototrack control?
