With Galil you do not necessarily need intelligent drives, AMC, Copley Controls & Aerotech for example can be used, but the likes of Baldor that require the drive feedback, in your case, resolver, they invariably will output a psuedo differential encoder type output which can be used by the likes of Galil for feedback to the controller.
Often the resolution can be programmed also.
