Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Read analog micrometer with webcam, what name to give the software ?
    Dec 2005
    netherlands
    Hi..
    I am looking for a name to give to GPL open source software i wrote.
    See screenshots below.
    Maybe someone here can come up with a suitable name for it ?
    Preferably a short name. (better for use inside the source code.)
    And a name which gives none or a few hits on google.
    Which makes it easier to find info on it for users.
    The software does this:
    Take a analogue micrometer.
    Aim a webcam at the micrometer.
    Then start my program.
    The prog takes a picture of the micrometer with the webcam.
    The prog finds the position of the needle on the micrometer.
    And displays the found value on screen.
    And puts the found value in a chart.
    Currently the prog can take 4 pictures per second on my slow celeron 700 mhz computer.
    This is 4 x 3600 = 14400 measurements in one hour :-)
    Can you beat this by eye and hand ?? :-)))
    All nicely stored in a chart in a image file.
    You can move the micrometer over a surface with a servo motor.
    Gathering lots of data, while you are sitting back and are smiling :-)
    A screen shot of the prog with an example.
    The example question is how much does this axis wobble ?
    The point of the micrometer is put on the 10 mm axis of a servo motor.
    The axis slowly makes several turns.
    Mean while the prog reads the micrometer 4 times per second.
    The result shows the axis wobbles about 20 micrometer.
    The resulting png file with the measured data.
    Hopefully someone can come up with a nice name.
    Vroemm.
    Dec 2005
    netherlands
    What happened to the screen shots i placed in the message ?
    Vroemm.
    Gold Member WeCheat's Avatar
    Aug 2004
    My vote is opti-mic would be nice if you could re post the pics and maybe a video.
    Greg
    Dec 2005
    netherlands
    Thanks for the name.
    It is surprisingly difficult to find a reasonable name.
    Is there something which is better then this principal of measuring fast ?
    Here are the screenshots again.
    Now the first two in smaller resolution of 800x600.
    It is likely the previous where removed because they exceeded the max resolution allowed on cnczone.
    Vroemm
    Attached Thumbnails Attached Thumbnails Read analog micrometer with webcam, what name to give the software ?-qpixy-screen-shot-21-jan-2009-800x600.jpeg   Read analog micrometer with webcam, what name to give the software ?-qpixy-screen-shot-21-jan-2009-brightness-chart-800x600.jpeg   Read analog micrometer with webcam, what name to give the software ?-qpixy-measured-2009-01-21-221112.data.txt-reduced-height.png
    Feb 2007
    us
    RAMView
    Remote Analog Micrometer Viewer
    Dec 2005
    netherlands
    Quote Originally Posted by WeCheat View Post
    My vote is opti-mic
    There is allready software called opti-mic.
    http://www.sharewareconnection.com/titles/optimic.htm
    Nice try.
    I had not thought of using 'opti' in the name.
    Thanks for the try.
    vroemm.
    Dec 2005
    netherlands
    Quote Originally Posted by ligito View Post
    RAMView
    Software named RAMVIEW allready exists.
    http://www.epie.org/k12/PCMAGUTL.HTM
    Thanks for the attempt.
    Vroemm.
    Dec 2006
    How about micCam. Did a google search and nothing came up.
    Very interesting program. Would like to see a video or pics of the actual machine setup.
    Brian
    Dec 2005
    netherlands
    Quote Originally Posted by bclark6716 View Post
    There is mic-cam software, 6 million hits.
    http://mic-cam.software.informer.com/
    The name could also be not related to measuring or webcams.
    Just a meaningless combination of characters might be ok as name.
    vroemm.
    Jan 2007
    I'd hesitate to use the word "micrometer" in the name of the software.
    The instrument being read is generally referred to as a dial depth indicator.
    I'm sorry. I'm obsessive-compulsive.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Dec 2005
    netherlands
    Quote Originally Posted by Eurisko View Post
    Its ok, it leads to new options.
    Like: DDICAM
    Which i liked.
    But there is DICAM software.
    http://www.dicamusa.com/Software.aspx
    Dec 2005
    netherlands
    ddithing ? :-)
    No software with this name.
    vroemm
  • Page 1 of 2 12 LastLast
    1. Window for the webcam ?
      By lelelodi in forum Screen Layouts, Post Processors & Misc
      Last Post: 09-25-2012, 07:31 AM
    2. Webcam Mounting Arbor
      By micsit1 in forum Machines running Mach Software
      Last Post: 04-28-2008, 02:02 PM
    3. micrometer
      By hkrok in forum Product and Manufacturer Announcements
      Last Post: 08-14-2007, 09:56 PM
    4. Ratchet/R-F stop micrometer
      By fpworks in forum Calibration and Measurement
      Last Post: 02-04-2007, 11:54 AM
    5. Webcam For Unatended Machining
      By intek cnc in forum General Electronics Discussion
      Last Post: 04-01-2004, 03:34 AM
