Well, if the slot is actually .701", a .701" gauge pin shouldn't fit at all. Simple physics...two bodies cannot occupy the same space at the same time. Unless you gauge using a press... .702" would be a tight fit with that pin, and .703" would be a slightly loose fit...I mean .002" is generally the tolerance for a press fit anyway...
LinkBack URL
About LinkBacks
