Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > Calibration & Measurement
Calibration & Measurement Discuss Calibration & Measurement here.
Old 10-03-2007, 11:58 AM
dougtyler's Avatar
dougtyler is on a distinguished road
renishaw ballbar
does anyone here, use a ballbar check on a regular basis.
If there is, do you check only in one plane, or all three.
Old 10-04-2007, 06:24 AM
kimpgray is on a distinguished road
Hi Dougtyler
Are you talking about a vertical milling machine ? if so X and Y is what I check and then a normal dti backlash check on Z unless it's being used for three axis interpolation then I do all three .
Hope this helps ,
PS Got any good tips about keeping the cable from snagging on enclosed machines?
Old 10-04-2007, 11:47 AM
dougtyler's Avatar
The only tip I can think of, is that when you attach the ball bar, have the cable wraped up one revolution. When the program runs, it will unwrap the one revolution plus wrap one revolution in the opposite direction. This means that the cable will only be wraped up one revolution, through the whole process. Hope this helps.
Haas Renishaw Probe Tazzer Haas Mills 17 07-06-2009 06:18 PM
ballbar software js412000 Calibration & Measurement 1 01-16-2008 11:26 PM
Renishaw tool setting djbarren General Metal Working Machines 8 11-14-2007 07:27 AM
Renishaw Probe on Haas VF-1 gromit68 Haas Mills 2 07-15-2007 09:04 AM
Mp7 Renishaw probe Cncjunkie CNC Machining Centers 5 02-02-2006 09:13 AM
