| Calibration & Measurement Discuss Calibration & Measurement here. |
| So Im buying a good calipers, probably Starrett. They're quite expensive so I want to get the right one. Is there any differance between the accuracy of the mechanisms in Dial or Digital. Im thinking digital simply for the ease of use. But maybe Dial are more robust. Any thoughts? Thanks. |
| Fwiw, the 15 year old cheap $20.00 chinese caliper with a dial gives me the same reading as a digital Starrett. Unless you need better than .001
| I have both Starrett and mitutoya mic's and calipers in my tool inventory. I have found that the Starrett stands behind their accuracy, their name, for recalibration. And besides, they are made in the USA! I use hand me downs from my dad which are hand me downs from his dad and Starrett still will calibrate them for you. As for digitals, keep them away from any magnetic source, they will be destroyed immediately! You get what you pay for! Steve |
Probably not more robust. These have a rack and pinion mechanism to turn the dial and it is very susceptible to clogging with dirt. |
| how do the digital ones sense location then, like glass scale? getting away from the rack and pinion is a good idea, but my preference is the dial. Before dials/digital vernier calipers were called very-nears, they are useful especially for roughing but use a mic when it counts. I like the good one's as well, B&S,Starrett, Mit., but they're all equally toast as soon as you drop them |
Tut, tut, a vernier caliper is a caliper with a vernier scale, a digital caliper is a caliper with a digital display, a dial caliper is a caliper with a dial display, but I am not sure what a dial/digital vernier caliper is. The digital location system is some form of magnetic sensing; somewhat analogous to a tape recorder head moving along a strip impressed with a changing magnetic field. |
i should have omitted the word "vernier". to state more precisely, the error, comes from the rigidity of the frame vs a mic so is present with dial and digital calipers. I look to calipers to get me within a thou, a mic to get less than a thou |
#10
| I myself like dial thats just me i trust them more my guys in the shop like didgys but keep in mind calipers "no matter what are still just a referance tool" if you want a good true mesurment you need mics.
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
#11
| The standard is 10 times the accuracy of measurement if you are measuring .001 then use something that can measure .0001 so basically if you need to measure to .001 use Mic's if your tolerance is +/-.005 use calipers. I've found my mitutoyos are good to a thousandth of an inch and they are digital but we have a calibration department so when they're done throw them away. |
#12
Scott
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Cannot dial in a Series II - any ideas? | tomindallas | Bridgeport and Hardinge Mills | 9 | 01-01-2007 10:44 AM |
| Dial Bore Gauge Lubrication | itsme | Calibration & Measurement | 4 | 11-04-2006 08:44 PM |
| Have High Speed Modem, and Dial up Using Router | tobyaxis | Computers and Networking | 46 | 07-23-2006 09:17 PM |
| Proper use of dial indicators. | Cowbell | General Metalwork Discussion | 1 | 01-23-2006 04:37 AM |
| what does dial indicator use to measure? | cnc2k | General Metalwork Discussion | 9 | 07-16-2005 07:20 AM |
