Results 1 to 4 of 4
Thread: Electronic Digital Mic Tolerance
    May 2010
    I bought a Fowler 0-1 electronic digital micrometer. This is the first micrometer that I have ever owned.
    I measured some ballscrew balls that had been marked from the distributor. They said .12635. I measure .12600. I have cleaned the faces thoroughly, and zeroed the unit using the same friction setting used to measure.
    The mic also came with a small ball in a rubber holder to presumably use as a gauge. It measures .19650. I assume it should be .19685 or 5.000mm.
    Am I missing something, or is my mic off .00035" for good?
    Should I return it?
    Feb 2009
    And that's why I use my old mitutoyo standard mics. I would return it regardless if it could be calibrated, should be good righ out of the box. Not sure ifnthe digital ones have the spanner and adjustable barrel to calibrate them.
    May 2010
    It did come with a small spanner wrench. I don't have a clue what to do with it, though.
    May 2010
    I sent the unit back to Fowler. They repaired it or sent me a new one.....cant tell. This one reads right on the money across a range of Mitutoyo gauge blocks from .125" to 1"
    Just thought I would say how things turned out.
  1. Digital Version of Digital Machinist
    By castiron43 in forum Village Press / Digital Machinist
    Last Post: 01-29-2013, 09:41 AM
  2. CNC Using Electronic Digital Vernier
    By Art99 in forum Mini Lathe
    Last Post: 07-12-2010, 07:27 PM
  3. Need Help!- ISO Tolerance Help?
    By Billet Sean in forum General Metalwork Discussion
    Last Post: 06-17-2008, 08:04 PM
  4. Q: Tolerance - How much is to much?
    By Deviant in forum Mechanical Calculations/Engineering Design
    Last Post: 03-28-2007, 04:23 PM
  5. tolerance
    By heilcnc in forum Benchtop Machines
    Last Post: 04-29-2006, 09:31 AM
