Looking for Edge Finder with 1/4" Shank
Results 1 to 12 of 12
Thread: Looking for Edge Finder with 1/4" Shank
    Registered GeorgeIoak's Avatar
    May 2013
    Default Looking for Edge Finder with 1/4" Shank
    Almost all of the edge finders I've seen have either a 1/2" or 3/8" shank. I use a Bosch Colt Router so the maximum shank is 1/4". Does anyone know of any edge finders with a 1/4" shank?
    Aug 2009
    us
    Default Re: Looking for Edge Finder with 1/4" Shank
    Fisher Machine makes a 1/4" shank edge finder, just look on eBay.
    MICRO EDGE FINDER BY FISHER 1/4 or 3/8 or 1/2 SHANK | eBay
    But the max speed they recommend is 1500 rpm, will your router go that slow?
    May 2013
    Thanks for looking but I saw that one and no I can't go that slow. So the hunt continues...
    Member awerby's Avatar
    Apr 2004
    You don't need to turn the router on when you're finding edges. Just feel the edge where it is offset; you can actually feel smaller differences than you can see.
    Aug 2009
    us
    Andrew, have you ever done a test to verify how accurate that is? Compare it to a reading with a spinning spindle using a mill
    I'm wondering whether it wouldn't work to spin the router by hand, or rig up a way to spin it with a dremel or something. I have the same need...
    May 2013
    Good point about not having the router turned on. Might be worth a shot to try it. It just seems a bit odd to me that there really aren't any 1/4" shank solutions.
  7. #7
    Dec 2009
    Hi guys just a question ? are you using Mach3 if so why bother with a edge finder when you can use a a probe
  8. #8
    May 2013
    Yes, I'm using Mach3 but when I inquired about this in another thread people said to use an edge finder. I actually have a couple of probes but never go around to "programming" Mach 3 for the touch routine.
  9. #9
    Dec 2009
    Well a probe is the only way to go I have built a complete set of routines. All that you will ever need and I can help you through any issues.
    that you might have
    Look for Squirrel Probes in this site I just posted a new download link yesterday these work with Mach3 using a standard screen set .
  10. #10
    Dec 2009
    Just another note I never use a probe in the spindle chuck I always use it offset this eliminates any discrepancy in the probe ball and does not require the probe to spin true .
  11. #11
    May 2013
    I went to that thread to check out your routine but it says that the download link is broken.
  12. #12
    Dec 2009
    https://dl.orangedox.com/nVdNa3IFiTCchbpdIu
    this is the link in my last post i just tested it
    it's working.
    Let me know if it does not work
