Hello.
Can you explain how you calibrate the machine?
Best regards
My machine is equipped with start shaphon controller. I went through hell to configure the electronic gear through trial and error. The difference between the controller movement and actual movement is 4mm. It uses numerator and denominator way of configuration. Please see the attached pdf page 29-30
Hello.
Best regards
