Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Cadkey / KeyCreator
Cadkey / KeyCreator Discuss Cadkey / KeyCreator software here.
Old 09-07-2007, 11:26 AM
hancast is on a distinguished road
Cadkey 99 in Windows Vista
Has anyone had luck with cadkey 99 in windows vista. I did get program to run but doesn't like my wide sreen monitor. I have went to options and changed the screen display and it works after playing with it a bit but next time you open the program it is distorted in width and heighth again.
Old 09-11-2007, 11:23 AM
moldcore is on a distinguished road
Try stretching the window as far as it will go to the maximum size by grabbing the corners, then click on the maximize button. If my memory is correct there was an issue as you described it with every install on XP and Win2000/NT. Once you did the stretch routine, the issue would not repeat until you had to reinstall. Not sure about Vista however. I do know that there are issues with vista and KeyCreator in using the help files so Vista is not a recommended platform for KeyCreator at this time.
Old 09-14-2007, 09:33 PM
cadcamham7 is on a distinguished road
Ditto to the wide screen. Try drawing a circle and you get and ellipse.
Old 10-02-2007, 06:01 PM
5S Dude is on a distinguished road
We just got Acer AL2223W flat screens in our engineering department and to fix this issue;
click on "Tools" then "Options" and click on "Display". Set your Screen Size to what your monitor is and your circles will come out round again.
Old 10-10-2007, 09:19 PM
Thumbs up Thanks
Thanks.....I have done some work at home for two years.....and I just ignored this problem on my laptop computer. This was never an issue for 14 years at work because of normal size monitors.
I really appreciated that. I will always learn something new....
Archery, Ham Radio, CadKey, SolidWorks, FeatureCam.
www.fbcms.org
Old 12-16-2010, 01:51 AM
kodash9 is on a distinguished road
CADKEY 97
Speaking of old Cadkey versions, you wouldn't happen to have a copy of cadkey 97 or even an extra copy of 99 you want to get rid of, do you??
Windows Vista Please help SWPM Surfcam 5 10-06-2007 09:53 AM
Dolphin & Windows Vista TZ250 Dolphin CADCAM 5 06-07-2007 11:41 AM
Windows Vista SWPM Solidworks 1 05-01-2007 11:35 AM
surfcam and windows vista? dcrblazer Surfcam 2 03-07-2007 06:30 PM
Here it comes...Windows Vista... fatal-exception Mach Mill 2 02-08-2007 10:56 PM
