Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Cadkey / KeyCreator
Cadkey / KeyCreator Discuss Cadkey / KeyCreator software here.
Old 02-06-2007, 08:55 PM
Nigel_B is on a distinguished road
Any keyCreator Users here
Hi
I have been using Cadkey since version 3 and currently use 19. At the time I bought 19 it was just about finished and I got a copy of keyCreator with the annual contract.
The changes were so extreme I found it hard to change over.
However I have used it to create solid fasteners etc and taken them back to 19
KeyCreator seems to much better but it is just difficult to get used to all the changed menus.
If I want to get into keyCreator is there any one here to give me some advice or recommend a good forum.
Nigel
Old 02-07-2007, 02:55 PM
moldcore is on a distinguished road
Nigel,
If you have an annual contract them you should have access to the KeyCreator forum at: http://www.kubotekusa.com/cgi-bin/wfbin/ultimatebb.cgi
There is also this one: http://cadchat.com/forum/index.php
We can also help you here.
I’ve found KeyCreator to be much, much better all around. Is it without fault? No, unfortunately I get a crash once in awhile. My advice is to stop using CK19 and use KeyCreator full time and force yourself to learn it. If you do any serious solid modeling then you need to move up. KeyCreator is far more powerful with advanced modeling tools, and you can build assemblies using referenced parts and layout mode has been improved 10 fold.
Old 02-07-2007, 05:43 PM
Thanks moldcore
I was not using keyCreator so I let the AUC lapse.
19 was able to cope with my needs, but even with my limited playing around I can see that keyCreator is way ahead.
Thanks for the offer of help, I will also check out cadchat
2 problems I have at the moment:
I use L to bring up the line menu and it works initially after starting the program, but after a while when I press L the whole screen goes half size then jumps right back to full size.
Trying to use X to bring up the delta tranform menu, go through the process but can't make it stick. All I end up with is delta copy not the choice of move,copy,join.
Any ideas, the L problem is the one I really need to fix, if I close and restart it is fixed but you can't keep doing that.
And I have the 3.02 patch in place.
Nigel
Old 02-07-2007, 09:11 PM
Nigel,
If you have a legit copy, you should still be able to get on the Webforum. All you need is an account number from when you purchased KeyCreator. It’s in the “Help/about” info.
As for the L and the X keys, you should be able to find out if they are assigned to the right functions under Tools/Customize/ Commands tab. You may have more than one command assigned to L key if that’s even possible. You can assign whatever command you want to any key there. Make sure you have the “Save current Workspace on Exit” checked in the Tools/Option/Startup window to save any changes to the hot keys. Good luck.
Old 02-07-2007, 09:30 PM
Thank You
Yes my copy is legal so I will try to join that website.
2 things I can't find are Smart Layout which throws 4 views at once into the layout and I can't as yet find how to simply relocate instances using the cursor, can align them OK but not relocate them.
Photo Real, I am sure is not there, I used to find that very useful to do "photos" of tapware before anything was made.
With some playing around I was able to make things look Gold or Chrome and they looked just like a real photograph.
I guess I was the only person that found a use for it, as is no longer there.
Thanks for your Help
Nigel
Old 02-07-2007, 09:48 PM
Went to register with Kubotek and it says only active AUC customers can play.
Old 02-08-2007, 07:32 AM
spider is on a distinguished road
Originally Posted by Nigel_B View Post
Thank You
Nigel
-what version are you using?
-for "smart layout" look at the picture below...
-to relocate instances use (or any other thing for that matter) EDIT / ENTITIES / MOVE
-i'm not sure what you meen by photo reall, i can't find it in ck99, but look at the other picture below for some options....
The only thing i find stupid about it is the new icons they introduced back in 4.5 i think....but if your going to learn it, learn it with the new icons, i'll make your life easyer down the road. (fyi, there is a option to switch them the same as ck)
ID:	31238   Click image for larger version
ID:	31239   Click image for larger version
Old 02-08-2007, 01:35 PM
Sorry I didn’t know that. My AUC expired once and I was still able to access the forum. I renewed about a year ago after skipping a year.
Old 02-12-2007, 06:44 AM
Hi
I won't be going any futher than the V3 I have. Most of my work these days is cnc turning. Do get some drafting work, but not enough to need to stay up to date with the software.
I used to be able to toggle the direction of dimension arrows before finally placing it in position. Used to be alt I to undo the dim then control A to change the direction and then I could put the direction in place with arrows the way I wanted them. Is this possible?
I use L to bring up the line menu but after a while all the L key does is reduce the whole screen to half size and then bring it back to normal, any ideas?
Thanks Nigel
Old 02-12-2007, 06:55 AM
As far as I know (i could be wrong) but the only way to change the witness stile is to eather pre set it before making the dimension or use "change witness stile" to change the arrows.
As for the L key problem....I could have sworn i seen that same complaint soemwhere else....but then again i'm running on 2h sleep so i could be wrong. I'd check to see the button is assigned to the appropriate command.....(i'ts all i got)
  #11   Ban this user!
Old 03-30-2007, 01:16 AM
jamfixer is on a distinguished road
Hi
Nigel
having been a cadkey/key creator user since its beginning, hack and slash only works for so long,or as long as you need it,keycreator is just fine for hack and slash work,for real design work try solid works or alibre
or use it in clasice mode
  #12   Ban this user!
Old 06-07-2007, 12:26 AM
triumph406 is on a distinguished road
I used to hear the same rubbish from Pro-E users, for real designers use Pro-E, hacks us Cadkey.
I can't tell you how much crap geometry I get from Pro-E and Solidworks users. I design stuff in CK99 and WS21.5 that you wouldn't attempt in SWX.
In reality though it's not the software that makes the difference, it's the soft stuff between the ears that makes the difference.
Looking For Users ninewgt Ability Systems - LPT Indexer and G-Code 5 04-02-2009 03:37 AM
Cadkey19 vs KeyCreator dpryor Cadkey / KeyCreator 2 02-20-2006 06:10 PM
How many users? S4 Monster SprutCAM 9 11-24-2005 08:06 PM
V17 users??? turmite BobCad-Cam 15 07-27-2005 01:24 PM
Over 900 users!! HomeCNC CNCzone Club House 16 06-19-2003 10:34 AM
