Results 1 to 2 of 2
Thread: Wacom Graphire Tablet
    Oct 2005
    Post Wacom Graphire Tablet
    I'm running Cadkey19 and just bought a tablet. I want to digitize drawings to be cut on a laser, but the tablet is all over the place. Anyone had any luck with this? Do I need a special driver?
    Sep 2006
    Hi, I use Cadkey ver 7, and I also use a Wacom tablet, but not together. As far as I know, and I only use the cadkey and tablet for hobby use, the Cadkey will produce drawings to co-ordinates that you decide, whereas the Wacom tablet will follow the movement of the pen on the tablet as your hand guides it, much like a mouse but more precise.
    As I understand it to "digitise" a drawing, are you referring to having a plain drawing of some object and trying to pick up co-ordinate points that will be converted to digital information that will be fed to a laser cutting machine?
    I would assume that anything that you wanted to cut with a laser, mill, router
    or anything that is CNC controlled, then the drawing would have to be drawn with the co-ordinate points to set the program.
    If I'm wrong on this just disregard the previous.
    Ian.
