Results 1 to 7 of 7
Thread: Transform solid to line drawing
    Jun 2009
    Question Transform solid to line drawing
    I have been using Cad Key for solid modeling and tool path G coding. I would like to design and make a squirrel guard, from thin sheet metal, for the bird feeder. This would look like a rat guard for a ship's mooring line. More specifically, a truncated cone with a cylinder attached to the apex of the cone.
    I have tried various combinations to develop the flat drawing of this and have not been successful. Perhaps model and remove faces or extrude faces? As powerful as CadKey is this seems to be doable but I have not broken the code. Looking for suggestions. Some call me Carlos.
    Apr 2003
    What version are you using? KeyCreator has some Sheet metal tools that may help.
    Jun 2009
    Thanks for your response Moldy. I am using Cadkey 99 1.0
    May 2006
    Do you have the fastsurf option loaded?
    inside of Apps icon
    There is the surface unwrap function
    Cadkey 19
    Pm me if you don't have it
    Been doing this too long
    Jun 2009
    Bostosh, Yes, I do have Fastsurf. I have tried your suggestion and keep getting an error message.
    Fastsurf/Applications/Unwrap/Enter the chord height tolerance/0.010/Select the surfaces to unwrap/Single/ Error message “No Surface entities selected”
    I've modeled the truncated cone using solids Create Solid.
    May 2006
    The hierarchy of geometry is wire to surface to solids.
    you must reduce the solid to a surface to unwrap which generates wires
    Fastsurf is a derivative of something we used in Aerospace to unwrap complex geometry for cutting sheet composite materials
    Jun 2009
    Thanks Bostosh, I have cobbled something together using your leads, and a thousand nods of the head against a brick wall, and I can construct a developed truncated cone with a small cylinder on the small end. Some call Me Carlos.
    1. Which drawing/solid modelling package
      By fitzpatrick2362 in forum General CAM Discussion
      Last Post: 03-06-2011, 11:20 PM
    2. Problem- Drawing onto a Solid Model
      By mcmachining in forum BobCad-Cam
      Last Post: 07-30-2009, 02:15 PM
    3. Need Help!- MasterCam Machining Solid Drawing
      By stevec in forum Mastercam
      Last Post: 03-08-2009, 04:08 PM
    4. How can I 3d/Solid a line drawing?
      By PeteGallo in forum General CAM Discussion
      Last Post: 04-23-2007, 11:05 AM
    5. Transform 2D Views into 3D CAD drawing...?
      By tdfsu in forum General CAM Discussion
      Last Post: 02-03-2006, 03:05 PM
