Results 1 to 4 of 4
Thread: CK97R2 radius dimensioning bug?
    Oct 2006
    Greetings,
    CK97R2 on W98 Pro (on VM Ware Fusion on an Intel McBook Pro):
    • attempting to dimension bend radii according to CK97 tutorial, the leader lines are positioned entirely incorrectly
    Tried is several times and several ways. Can't get it to work.
    I DO get a bunch of CK Solids errors/warnings when I launch.
    Anyone have any ideas?
    Thanks,
    jv
    Apr 2003
    It’s been too long since Cadkey 97 but from what I recall there was problems with Radius dimensions that were fixed in later versions. I recall having to label radiuses as a workaround. Solid errors were very common in those days. While Cadkey was ahead of its time in those days, it still had serious problems with solids and was not considered a serious solid modeler. We only did wireframe because of the problems. There was add-ons like Draft Pak, Fast Surf that made it very productive. Save often under different names and seriously consider moving up if you can. The current KeyCreator is fantastic, it blows Solidworks away in every category including price
    Oct 2006
    thanks - partial resolution
    Thanks for the reply. I was hoping someone was still paying attention to Cadkey!
    I tried dimensioning a radius on a fresh part file, and it worked. There is apparently something about the tutorial part it doesn't like, maybe the view, the construction plane, or something. I can live without it, I don't imagine I will need dimensioned drawings for what I'm doing.
    Thanks.
    jv
    Oct 2006
    follow-up radii dim. bug in layout mode only
    I'm now pretty sure I only see this bug if I'm in layout mode, which, unfortunately, is probably where you need the feature.
  1. Need Help!- 2D Dimensioning in 3D?
    By PinMan in forum BobCad-Cam
    Last Post: 04-28-2009, 01:01 PM
  2. Need Help!- Dimensioning
    By IBigBoy in forum BobCad-Cam
    Last Post: 03-26-2009, 02:24 PM
  3. Need Help!- Dimensioning A Solid
    By TZ250 in forum BobCad-Cam
    Last Post: 02-13-2008, 08:12 AM
  4. Dimensioning and help files?
    By LorenzoNH in forum TurboCAD/CAM
    Last Post: 04-27-2007, 03:33 PM
  5. Dimensioning?
    By Ken_Shea in forum OneCNC
    Last Post: 07-09-2003, 09:51 AM
