Newbie STL File / Mesh Editing Capabilities in KeyCreator
Results 1 to 2 of 2
Thread: STL File / Mesh Editing Capabilities in KeyCreator
    Registered briankb's Avatar
    Sep 2012
    Question STL File / Mesh Editing Capabilities in KeyCreator
    What abilities does the current version of KeyCreator (2014) have to open and modify STL files?
    For instance you can open STL files with SpaceClaim and edit them, if you have their STL-Add On they provide a group of tools specific to merging various mesh and solid objects into other mesh objects. I'm just wondering if KeyCreator has any of these capabilities.
    Member mactec54's Avatar
    Jan 2005
    Default Re: STL File / Mesh Editing Capabilities in KeyCreator
    briankb
    You can import & export STL files with KeyCreater (2014) I have not used it, but I don't think there is any file format that you can't import, & work on the drawings, it has many options, it supports every major Cad manufacturer's cad format
    Best to contact tec support, they will tell you, if you can do what you want to do, I'm almost sure though, you can modify other STL files with out any problems
    Mactec54
