Need Help! Move part after layout?
Results 1 to 2 of 2
Thread: Move part after layout?
    Jul 2012
    Default Move part after layout?
    Is there a way to move a part after creating a layout for it. If I create a layout and then move a part it screws up the layout model. And having a layout layer is starting to get crazy. Thank you.
    Member moldcore's Avatar
    Apr 2003
    No I’m not aware of any automated way. They should stay attached but the dimensions will probably need to be adjusted using generic move. If you rotate a part it gets even more missed up. It’s best to just leave the layout until the design is finished or you will be chasing your tail.
