Results 1 to 8 of 8
Thread: where to buy gear cutters and splinde broaches
    Mar 2005
    us
    where do you get cutters to machine teeth for small gears?
    #2 also to cut teeth for gears on small belt drives
    #3 where do you buy say small 3/8 inch or close to splined shaft and broaches?
    Jul 2007
    United Kingdom
    What's your budget?
    #2 I would grind a flycutter and cut the teeth individually with the gear blank on a dividing head.
    #3 You can buy milling cutters but they are not cheap and you need a different cutter for each DP (Diametrical Pitch) or Module number that you use and each cutter only covers a small range of size (ie No. of teeth). Look for Involute gear cutters on Google there are lots of sources in the UK. Second hand stuff is cheaper look at www.homeand workshop.co.uk or a company called Tracy Tools Ltd. (no website) +44(0)1803 833134
    Good Luck!
    Dec 2007
    Small End Mills
    We have cnc milled small gears using miniature end mill bits from http://www.bitsbits.net/.
    They are not gear cutter mills, but are miniature long reach end mils.
    McMaster-Carr also carries some miniature end mills although not with as long a reach.
    Registered putputman's Avatar
    Jul 2007
    Be very careful when you buy gear cutters. I bought a set of 48P cutters from Traverse and they were made in China. Profiles looked like they were machined with a hatchet. Complete junk. Sent them back.
    Bought another set from McMaster-Carr. They were made in Poland and were excellent cutters. The profiles and cutting depths were good. I have purchased some other pitch gear cutters from McMaster-Carr and they were also good. They are not cheap, but are worth the price. Sell them on Ebay when you are done with them.
    Sep 2006
    Ireland
    Hi There,
    Tracy tools have a website at, http://www.tracytools.com/
    I have found them to be excellent to deal with, and fast postal service
    Regards
    John O Regan
    Nov 2005
    If you need gear cutters, or for that matter just about anything else, try MSC. Admittedly, they are not cheap, but quality tools made in USA never are.
    http://www1.mscdirect.com/CGI/NNSRHM
    Brainstatic
    Nov 2005
    Also, you could make your own perhaps. Ivan Law describes a lathe-based method for achieving this end, as well as a relief cutting tool, in his book "Gears and Gear Cutting (Workshop Practice) (Paperback)." It contains very understandable treatise on all aspects of gears, highly recommened.
    http://www.amazon.co.uk/gp/offer-lis...785531-7559864
    Brainstatic
    Mar 2005
    us
    thanks for the help it is greatly appreciated
    1. Basic Bevel Gear - Milling a valley for gear teeth
      By ngr1 in forum General CAM Discussion
      Last Post: 04-05-2012, 10:55 AM
    2. Fly Cutters?
      By BrendaEM in forum Benchtop Machines
      Last Post: 03-11-2007, 09:32 PM
    3. Spur Gear / Gear Rack
      By ckrantz in forum Linear and Rotary Motion
      Last Post: 12-07-2006, 12:06 AM
    4. How to tell what cutters go with what?
      By ZipSnipe in forum Benchtop Machines
      Last Post: 04-06-2006, 01:55 PM
    5. New member looking for fine gear cutters.
      By Laszlo in forum CNCzone Club House
      Last Post: 06-15-2004, 08:58 PM
