Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: My Forrest Edward's 5 Radial Project
    Registered Ivy McNeil's Avatar
    Feb 2004
    Hi All
    This is my first post here, I have been lurking for quite a while, I thought I would show everyone what I have been doing.
    I have started building a 5 cylinder radial engine " Forrest Edwards 5 " and it has turned into quite an undertaking ( lots of hours ).
    Here is a link to my Photobucket Album of the parts I have made so far.
    http://smg.photobucket.com/albums/v6...dial%20Engine/
    Regards
    Ivy McNeil
    I did not fail,I found 10,000 ways that dont work
    Mar 2005
    Toronto, Canada
    welcome to the forum, the engine looks good, there's just something about radials is very cool, maybe its all the aeronautical history or the sound or just that they look great ... when does it get fired up?
    Feb 2004
    Hi Mcgyver
    It wont get fired up for a while, I am just finishing up yhe outside parts right now.
    There is a lot of internal parts to make yet, I think the crankshaft will be next
    item.
    Regards
    Ivy
    Banned
    May 2006
    England
    Nice work there, looks very complex!
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Nice work. I have had the Edwards plans for ages. I got as far as a bad tool path for the valve, and one end of a set of pushrods, but then got side tracked to a making a lathe spindle micrometer stop to acurately position the pushrods to machine the other end.
    Regards,
    Mark
    www.wrathall.com
    Aug 2006
    where did you get your plans?
    Feb 2004
    Hi wildwestsydney
    I downloaded them at http://groups.yahoo.com/group/R_and_R_engines
    I think you will have to join the group to download from the file section.
    Ivy
    Feb 2004
    Hi Guys
    Here's an update on my progress,I have finished the heads and assembled the case.
    I started working on the crankshaft today.
    Here's a couple photos.
    http://img.photobucket.com/albums/v6...e/im001461.jpg
    http://img.photobucket.com/albums/v6...e/im001464.jpg
    Ivy
    Banned
    May 2006
    England
    That is looking excellent Ivy. Very complex, I wish I could do stuff like that it must take forever! Do the valves seat on the aluminium?
    Feb 2004
    Hi Nick
    I am following the plans and they show the valves seating on alum. , If I have a problem with it I will install a hard seat.
    I finished turning the crankshaft today leaving grind stock, after I grind I will press the rod journal in.
    Ivy
    Pics of crankshaft
    http://img.photobucket.com/albums/v6...ankshaft-1.jpg
    http://img.photobucket.com/albums/v6...crankshaft.jpg
    Banned
    May 2006
    England
    Hi Ivy,
    All looks excellent workmanship. I suppose if people have built the engine successfully in the past, the aluminium valve seats should be fine.
    You're making great progress there.
    Nick
    Registered T.L.A.R. eng's Avatar
    Nov 2005
    Ivy, I have admired your workmanship in your photo's. I am anxious to see the finished engine in detail and hopefully see a video of the engine running.
    Are you going to use the oil pump as drawn? What oil are you going to use?
  • Page 1 of 4 1234 LastLast
