Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 60
Thread: F1 engine project
  1. #37
    Registered derekj308's Avatar
    Jun 2005
    Hi Stevie
    When you do get around to machining your crank are you aware that although your design may be statically balanced (i.e. the crank would stay stationary in any position, not roll around to the same position each time) it won't be dynamically balanced. I have read a lot of your posts and I'm betting you are aware of this but I thought I'd throw it in just in case you weren't. I haven't had a direct involvement with dynamically balancing a crank during the design phase so I'm no expert but I do know it can be designed out and that only super fine tuning is required afterwards. I'm not sure if you could add 'heavy' weight or remove material from the counterbalances of a statically balanced crank to achieve a dynamically balanced crank or whether you need to design the offsets in first and that the adding/removing is just fine tuning.
    Cheers
    derekj308
  2. #38
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Felix Wankel started his career doing rotary valving in the heads of four stroke torpedo engines during the war.
    Regards,
    Mark
    www.wrathall.com
  3. #39
    Registered itsme's Avatar
    Jun 2004
    United Kingdom
    Go Felix!!!
    Just as a matter of interest, have you considered hard chrome plating for the bores? Nickel works just fine, however I do know from model aeroplane engines that chrome is generally more tolerant of 'abuse'.
    Also, take a look at this:
    http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
    That piston looks a tad on the heavy side...
    Regards
    Warren
    Have a nice day...
  4. #40
    Feb 2004
    hh
    I send stuff for chroming all the time; i could do the liners
    but; chrome will not wetout like Nickel
    I might be re-designing the piston design; I like the smaller head; short skirt 2 ring set-up
  5. #41
    Feb 2004
    hh
    hey Warren
    Thanks; that listing helped be out a bunch
    Heres a revised piston design
    No piston crown yet; and I need to add the small lightening pockets each side of the pin etc; surfaces will be needed for cutting; but it looks good; I might shorten the stroke some more
  6. #42
    Feb 2004
    hh
    I'm cutting the bottom profies now on the mini mill; I programmed for Alum so on this piece of cherry i've jacked the feeds up to 200%
    We'll see what it looks like injust over 21,000 lines
  7. #43
    Feb 2004
    hh
    Beside a AAA battery
    Not bad for Cherry
  8. #44
    Jun 2004
    United Kingdom
    Hi Stevie
    That looks great! Now you just need to add those pockets. Are you going to mill the pistons oversize and then turn them down to the final diameter?
    Regards
    Warren
    Have a nice day...
  9. #45
    Feb 2004
    hh
    yeap; I'll make a jig that pulls down on the wrist pin hole and finish turn them
  10. #46
    Dec 2005
    Norway
    Hi Steve, have you, or anybody else for that matter, ever considered using a CNC milling machine for grinding cranks and cams etc. This occured to me recently when I saw a video of a hobby type CNC millling machine operating as a lathe, the workpiece was in the spindle, very neat.
    Regards
    Phil
    Quote Originally Posted by Stevie
    ........ if a new machine is needed for say grinding the cams; well i guess I'll just have to build one.........
  11. #47
    Jan 2006
    Check out this place http://www.conleyprecision.com/ They make 1/4 scale engines.
  12. #48
    Registered rhino's Avatar
    Oct 2005
    Hi Mark
    Wet liners; brass with Nickel plate; I'll try to find some high silicon alum cast stock to make the pistons from
    'scuse the dumbness but what is meant by wet liners?
    On the other hand, You have different fingers.
