Page 1 of 8 1234 ... LastLast
Results 1 to 12 of 92
Thread: Making a 671 Supercharger
    Oct 2011
    (Sorry if this might be the wrong place, i don't post to often here but i figured IC is the most relevant category.)
    For those of you who might not know, I work for Phillips Patterns & Castings in Muncie, IN, an aluminum Foundry and Production CNC shop. We making American made parts and I am an engineer, Foundry worker, Machinist, pattern maker, business manager.
    This is my build of a 671 supercharger, for my company, i started with a machined model, designed the pattern and coreboxes from it. Once the pattern and coreboxes are done i will be ready to makes some castings then machine them in our CNC shop. Once we have a completely machined case i will be making a video of the entire process.
    For anyone who is in manufacturing, interested in how things are made or just wants to show support for an American manufacturing company, you can follow us on facebook at www.facebook.com/DiamondP We post all of our builds and will be taking you through the in-depth processes that are required to manufacture a product.
    If anyone has questions, feel free to ask.
    Day 6-
    Machining pockets into the 1" aluminum plate that will be the pattern board, the blower pattern will be located and mounted on this board.
    Done
    Machining the pockets
    1" aluminum plate setting up for machining
    1 of 2 coreboxes, rough cut
    Day 3-
    Finished, The Lines you see are just pencil marks, now just need to mount it to a board, flip it and machine the underside pockets and cope coreprints
    3rd layer finishing cut
    Third layer cut and glued, rough cutting it then finish cut with a 0.25 ball mill, should be done today then start cutting the core boxes next week.
    Second layer completely done, will cut and finish the top tomorrow.
    Finishing cut on the second layer, tolerance ±0.0005, Z level drop is 0.0020. Half way done
    a photo of the CNC machine cutting the pattern, im cutting this in 3" layers of renwood. The layers are just super glued together then i post-process the tool paths and drip-feed it to the machine. This photo is of it doing a Z plan cut and leaving a 0.0500" machine stock.
    This photo is the designed pattern i am cutting.
    This photo is what the finished casting will look like.
    Registered stevehuckss396's Avatar
    Dec 2006
    It will be cool to see how it's really done. I'm watching!
    Registered dynosor's Avatar
    Oct 2006
    Thanks for sharing!
    Red to red and black to black, or it's ashes to ashes and dust to dust.
    Oct 2011
    Day 9:
    Pattern is done, ready to start cutting and mounting the gating and risers to it, second corebox has started to be machined and should be done by tomorrow. Still waiting the hear if we are buying a new flask or not to mold this. Also took a quick video walk around of the shop.
    http://www.youtube.com/watch?v=9Ai_hkUV9Dg]671 Supercharger Pattern Walkaround - YouTube
    machining the pockets out of the blower
    Machining Pockets
    Pockets done
    Day 8-
    Mounted the blower to the plate, machining the rest of the pockets and the pattern will be done.
    Screws
    Screwing down the blower to the plate
    Picture of a camera taking a video of what im taking pictures of
    Painting and sand the corebox and blower
    Day 7-
    Plate done
    Finishing Cut on the second layer
    Rough cut of the second layer done
    Rough cutting the second layer of the first corebox
    Cutting the cope coreprints
    Oct 2011
    Day 12:
    Second corebox is done, cutting the loose piece then the tooling will be ready to take over to our foundry, but i found out over the weekend it will be 1-2 weeks before we get our flask in to start molding . ill still make the gating and risers though.
    Unloading the pattern
    Rough cut of the first layer, second corebox
    Finishing cut on the first layer
    Second Corebox Done
    Starting on the loose pieces
    Oct 2011
    Day 13:
    Got a lot done today, finished the loose pieces for the corebox, fitted and painted them, started the basic layout of the gating and riser system of the pattern, took the coreboxes over to the foundry and made a few to get the weight of sand we will be using to calculate how much it will cost. Will be cutting and fitting the gating and riser system for the next few days.
    also i added a photo of the intake to supercharger adapter plate we will be making.
    a photo of a few patterns we've cast in the past , some of these patterns are 50+ years old, some even hand made.
    3D printed pattern of our supercharger to intake adapter we will be casting, going to be making the gating system on it for the next few days.
    Loose piece rough cut
    loose piece finishing cut
    Loose piece sitting onto of the corebox
    Loose piece in the corebox
    Air set station
    Sand hopper
    Sand striked off and setting in the corebox
    Core dumbed out and loose piece attached
    Cores, will be glued together before they are placed in the mold.
    Hard to tell, didn't get the camera straight, but this wall has negative draft of 3° from the corebox parting line, thats why we needed loose pieces
    Risers roughly marked out for placement, will be cutting and mounting them soon
    Gating system of the pattern, drag side, will be the same on the other side, 2 man pour.
    Feb 2011
    Dont you use filters under your sprues?
    Oct 2011
    Quote Originally Posted by slowlearner View Post
    yes we have a couple different kind, just depends on what the customer wants, ceramic, steel, fiberglass, weaved, foam, coated, uncoated.
    Feb 2009
    Love the post, keep it up!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Oct 2011
    Day 14:
    Tuff filling the seam lines of the pattern
    precision drawn riser blueprint
    to scale riser layout
    Riser pads cut and drafted 7°
    Grinding the risers
    risers line up
    Risers layed out on the pattern, these will be squeezed in the mold then lifted from the top before the pattern is taken out of the mold.
    The pads will be mounted onto the pattern with positive draft, the risers are drafted to pull from the top of the mold.
    Dec 2006
    This is cool as hell. Can't wait to see it cast in aluminum.
    Jan 2006
    HI , great to see such fine work and good old American Muscle Car industry manufacturing still alive and kicking ........... not via a boat from China
    Keep up the great workmanship.
    Cheers
    PS- Been on your " Diamond P Industries" website - do you ship parts to Australia ?
  • Page 1 of 8 1234 ... LastLast
    1. Making a Z gib for X3
      By binfordw in forum Benchtop Machines
      Last Post: 08-24-2010, 12:07 AM
    2. Supercharger design
      By Machine09 in forum I.C. Engines
      Last Post: 09-19-2009, 02:34 PM
    3. supercharger
      By metalhack in forum I.C. Engines
      Last Post: 03-04-2008, 03:31 AM
    4. Making M2
      By pekeX in forum General Metalwork Discussion
      Last Post: 04-06-2007, 08:47 AM
    5. Axial Flow Supercharger
      By devincox in forum Jet Engines and Ram Jets
      Last Post: 03-09-2007, 03:01 AM
