Results 1 to 5 of 5
Thread: need guidance on plans
    Jan 2011
    Greece
    hi guys,
    i want to build an engine and i do not know what plans to look for. i am searching a lot in internet and found many plans but i do not know witch is good or not.
    can someone with knowledge please let me know where to look for decent working plans?
    many thanks
    Registered stevehuckss396's Avatar
    Dec 2006
    You might get more help if you could narrow down what type of engine you are interested in building.
    Steam or Gasoline?
    Single cylinder or multi?
    2, 4, 6, 8 cylinder
    Automotive or aeromotive?
    There are so many options out there I really don't know which way to point you.
    Jan 2011
    Greece
    Hi Steve,
    thanks for the reply.
    i have to tell you that your thread ispired me to build my own engine .unfortunately i am not a pro like you. i come from rc model planes but i am interesting in ic engines in general.
    with short glance i think aero radials are easier in constraction. so i want to know witch one i should look for.parhaps a 9 cyl?but witch builder?
    please note that i do not plan to fly with this engine any model probably .
    did you finished the drawings of your engine?good luck
    thanks for your time.
    Dec 2006
    Quote Originally Posted by AchillesGr View Post
    Hi Steve,
    Yes I have finished my plans and many have purchased them.
    One of the finest sets is the Hodgson family. Not a build for the beginner but many have built the engine and many have succeded. I have the set and they are absolutely first class.
    Ageless Engines
    Strictly I.C. mag has build articles for
    THE HEINEN FIVE, by Jurgen Heinen. A ¼-Scale, Five-Cylinder, Glow Plug Ignition Radial Engine. Issue: # 16 & 17.....$8.00ea.....TOTAL: $16.00
    WRIGHT J5, by Karl-Eric Olsyrd A ¼-scale model of the 9-Cylinder Radial Engine used in THE SPIRIT OF ST. LOUIS in 1927; the Wright Whirlwind. Issue: # 24, 25, 26, 27, 28 & 29.....$8.00ea.....TOTAL: $48.00
    KINNER K-5, designed by Merritt Zimmerman - Built by Pieter Dekker. A ¼-Scale 5-Cylinder Radial, Spark Ignition Engine. Issue: # 36, 37, 38, 39 & 40.....$8.00ea.....TOTAL: $40.00
    THE 1/6th -Scale KINNER, by David Johnson. 5-Cylinder Radial with Glow Ignition. Issues: # 53, 54, 55 & 56.....$8.00ea.....TOTAL: $32.00
    And more are there. Email to see if the plans are included in the article
    Jan 2007
    Hi Steve,
    If you do not know a lot about building engines, start with a simple single cylinder. There will be enough there to keep you busy and hone your skills a little better and also, it might just work first time. Steam is more forgiving with regards to "tolerance" and it will run on compressed air. However there is more involved with boiler and burners.
    Kids at a local high school here have been taught (in classes no more than 6) to build a 30cc fourstroke water cooled engine. As a starter they build with just a poppet valve for the exhaust and if they get time, then they make up an inlet cam as well. Ignition is an old car coil and points. Four stroke easier than 2 stroke......yes I know there are no valves as such and no cams and gearing, but to get a piston sealing well enough for a 2 stroke can be involved. Valves on a four stroke take an effort as well but just remember to cut valve seat and valves without moving the topslide angle on the lathe. Works for me.
    1. Need some guidance
      By scrambled in forum General Electronics Discussion
      Last Post: 02-21-2009, 02:32 PM
    2. Cad Guidance
      By JMT in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-21-2007, 01:10 PM
    3. Looking for a little guidance!
      By jayty97 in forum DIY CNC Router Table Machines
      Last Post: 02-14-2007, 09:43 PM
    4. In need of guidance
      By xcphil in forum General Metal Working Machines
      Last Post: 05-29-2006, 02:41 PM
    5. I need a little guidance please....
      By Steve F in forum Servo Motors and Drives
      Last Post: 05-15-2006, 02:16 AM
