Results 1 to 5 of 5
Thread: Valve adjustment question
    Oct 2006
    Hello,
    I have a question about the valve adjustment on a kawasaki 350cc engine , it is in a club car (golf cart).
    It has overhead valves and rocker arms and pushrods. But there is no adjustment screws at the top . I do not think it has hydraulic lifters.
    It looks like to me you have to file off some material on the valve to get the clearance as you do on some briggs engines.
    Any Idea's? I figured I would ask before I started removing some material .
    Thanks !
    Registered neilw20's Avatar
    Jun 2007
    Just looking around, I believe they have shims of different sizes.
    Rather a pain to adjust, some worse than others.
    Is it that bad they need adjusting, because without the right strange tools expect some **&(*& adjectives.
    A few google searches should lead too some detailed information.
    Good luck!
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Oct 2006
    Neilw20,
    hello. I know what you are talking about with the shim adjustment. I am very familiar with that one as I am a full time motorcycle mechanic.
    This one has no shims (you are right , kind of a pain) just a simple rocker arm and push rods.
    The more I think about it the more I think I have to remove some material to adj it.
    Jan 2010
    I am not familiar with those engines. I once had a Honda 350 which adjusted by an eccentric rocker arm. The arm was rotated to achieve the clearence. Look on line for the info.
    Mentally confused and prone to wandering!!
    Oct 2006
    Yeah , I did a google search . I did not find out much. The guy at our local farm equipment store said it might have the eccentric rocker arm pin -- but I was not that lucky.
    1. Gib Adjustment Question...
      By Shooter7 in forum General Metal Working Machines
      Last Post: 11-25-2010, 11:31 PM
    2. Solenoid valve question
      By scrambled in forum General Electronics Discussion
      Last Post: 11-23-2010, 10:23 PM
    3. Interact 2 speed control valve problems (piloted 5 port 2 soleniod valve)
      By ichudov in forum Bridgeport and Hardinge Mills
      Last Post: 09-06-2010, 12:25 PM
    4. Cross slide motor/belt adjustment question
      By BrassBuilder in forum Vertical Mill, Lathe Project Log
      Last Post: 07-05-2010, 07:29 PM
    5. Tire Valve / Shraeder Valve Dimensions
      By jamiedaugherty in forum Mechanical Calculations/Engineering Design
      Last Post: 01-22-2010, 10:46 AM
