Results 1 to 4 of 4
Thread: PLUG WIRES
    Aug 2008
    united sates
    PLUG WIRES
    Hi what do you guys use for plug wires or dose anyone know where to buy then....For a quarter scale engine...1/4-32 plug
    Registered stevehuckss396's Avatar
    Dec 2006
    I used 600 volt MTW (machine tool wiring) on one of my engines and never a stray spark.
    I bought some wire from Roy Sholl at NAMES. He has 5, 10, 20, and 26 KV (thousand volt) wire by the foot. The diameter of the wire dictates what I use. They are all very good quality, silicon jacket.
    http://www.cncengines.com/ic.html
    Jan 2007
    spark wire
    mouser # 566-8899-100-02
    18 awg
    go to mouser and look for 8899.pdf for full details
    Registered Swede's Avatar
    Dec 2003
    Kind of a late reply, but it might help someone...
    The usual wire is stiff and crappy hookup wire, but a better alternative exists... look for some rubber-sheathed test probe cable, the same sort of stuff used to make probes for DMM's and such. It uses a very fine stranded copper that is as limp as a noodle, has extra-heavy sheathing, and looks totally scale. Remember that with spark ignition, voltage is the problem, current is not, so the copper does not have to be especially heavy, but the insulation does.
    I've used the stuff I mentioned, and like it a lot. You can see it here...
  1. need help id 8 wires
    By 15mgtar in forum Stepper Motors and Drives
    Last Post: 07-30-2009, 01:53 AM
  2. What wires should be shielded?
    By eat in forum General Electronics Discussion
    Last Post: 07-23-2007, 12:16 PM
  3. What wires to use?
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 02-21-2007, 02:02 PM
  4. Best way to keep wires out of the way
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 09:40 PM
  5. Lead Wires?
    By aggie_67 in forum Stepper Motors and Drives
    Last Post: 06-05-2006, 10:02 PM
