Results 1 to 3 of 3
Thread: control locks up
    May 2006
    U.S.A.
    control locks up
    I have an early model EZPATH lathe. after homing the machine at startup, then hitting the #1 key to change tool and offset and then changing to the right tool. bring it up to touch off the tool I hit the "F2" key to bring up the offset page the control locks up I can not see anything in the offset page it just stays blank but I can still move the carriage by turning the handles but I can't put in any offsets.
    I'm also wondering if i can put in a newer mother board the current is 486
    Jan 2005
    Did you try and reload the software?
    Mar 2010
    UK
    It was a long time ago when I was operating two of these machines and they would regularly lock up when going from the graphical simulation and back into run mode.
    The error on screen was a typical of a mathematical error. Cannot remember the exact error but basically I believe it was down to the PC motherboard having a CYRIX 486 CPU.
    Back eons ago when 486 PC's were the norm, CYRIX chips had a reputation for bad handling of Floating Point calculations.
    I believe swapping the CYRIX for an INTEL flavour CPU could well help you out.
    Regards,
    Rich.
  1. Axis locks.
    By BlackMoon in forum Industrial Hobbies (Support forum)
    Last Post: 10-30-2009, 02:00 PM
  2. Mach Locks Up
    By pzzamakr1980 in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2008, 09:30 PM
  3. g203v locks motor, but won't jog....
    By mxpro32 in forum Gecko Drives
    Last Post: 12-15-2007, 07:18 PM
  4. PC locks up sending to Mazak
    By xr135 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2006, 09:48 AM
  5. PC locks up with masterCam/Mazak
    By xr135 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 06-19-2006, 10:18 AM
