Results 1 to 1 of 1
Thread: EZ-Path z axis choppy only when spindle on
    May 2012
    With our ez path the Z axis works fine while the spindle is not on (not engage)
    But once the spindle is engage the z axis movement becomes choppy.
    However the x axis has no problem with spindle on or off.
    Does any one come across a mproblem like this?
    We check the voltages comming into the amplifier board, with spindle OFF
    107vdc with spindle ON 105vdc.
    Is that enough of a change to cause the problem with the z axis?
    Check the low voltages, they are all fine.
  1. surface finish choppy
    By tpsimer in forum Fanuc
    Last Post: 12-11-2011, 01:38 PM
  2. Bridgeport EZ-Path Lathe Spindle problem..
    By jdocmm in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 12-10-2011, 06:38 PM
  3. Need Help!- Losing steps, smooth jogging, choppy running.
    By Ranscon in forum Automation Technology Products
    Last Post: 10-26-2008, 05:19 PM
  4. Stepper running choppy
    By Smackre in forum General Electronics Discussion
    Last Post: 02-14-2007, 09:36 PM
  5. need help fet3 driver motor is choppy and slow at low steps per inch
    By mike10 in forum Stepper Motors and Drives
    Last Post: 01-02-2005, 03:41 PM
