Results 1 to 6 of 6
Thread: Wireing (460 to220 volts)
    Apr 2010
    Just bought a 1995 lathe, The tag on the back says 208 3phase, when I got it home and opened the cabinet it says 460 volt 3phase. Nobody can seem to tell me which way it was wired when it was taken out of service. I need to have it set up for 220volts. I have no manuals for this thing either, they said they where in the cabinet but my luck there not there, any help would be appriciated. Thank you.
    Dec 2003
    Is this CNC or a manual lathe? if manual it is just the motor probabally that you have to worry about, in that case look on the name place of the motor for the 220/460?
    If CNC there most likely is a transformer in the enclosure that may indicate what it is hooked up as.
    Also the main fuses should be an indication as they would be half the value on 460v.
    Apr 2010
    THANKS, This is a cnc ez-path. The transformer in the cabinet shows that it is wired for 460v, but there is also another transformer under the tail stock end that I have know Idea witch way is wired, also don't know witch one is the primary one. Thank you.
    Dec 2003
    You can usually go by size comparison as the the primary one being larger.
    But as a rule the primary one is either in the enclosure or on the outside of the machine feeding the enclosure disconnect.
    Apr 2010
    Everything I look at says its 460, Is there a way I can get from the 220 volts back to the 460volts with out rewireing the whole machine? Thank you.
    Oct 2009
    uk
    Hi
    Hi get a inverter single to 3 phase just make sure its the right ampage,
    philip
    1. WIREING HARNESS
      By AB PRODUCTS 1 in forum Haas Mills
      Last Post: 09-30-2010, 02:29 PM
    2. wireing so far
      By stk2008 in forum General Electronics Discussion
      Last Post: 09-17-2009, 01:19 PM
    3. Hobbycnc wireing help needed
      By bgriggs in forum Hobbycnc (Products)
      Last Post: 10-03-2007, 09:37 PM
    4. Boosting three-phase 240 Volts to 480 Volts
      By Old Car Guy in forum Phase Converters and VFD
      Last Post: 05-01-2006, 10:27 AM
    5. Can anyone help me with some wireing
      By SCOTTY in forum General Electronics Discussion
      Last Post: 07-22-2005, 07:07 AM
