Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 01-18-2012, 02:25 PM
dougputt is on a distinguished road
R2E3 x axis trips in rapid one direction
Hi
Wondering if anyone else has had a problem with X axis faulting when rapiding one direction only.
I can get it to move ok if I overide the feed and dial it down to say 50% Anything more than that and I get the axis tripping off and loud buzzing from R/H panel where drives are
Old 01-19-2012, 03:51 PM
So it is not the drive that is buzzing but one of the relays in the box on R/H side bottom. Had a similar thing on my Fadal, I will try and replace that relay
Old 01-19-2012, 07:59 PM
So whenever I go in a negative direction in X at G0 it trips, but in positive direction it's fine.
if I use G1 and feed of 250 it won't trip but it's not moving as fast as it should
R2E3 z axis travels dougputt Bridgeport/Romi Lathes 1 02-25-2012 10:50 PM
lost origin when y axis limit switch trips timmydabull Haas Mills 10 04-04-2009 12:44 PM
Problem- R2E3 Intermittent axis limit Jadaan27 Bridgeport and Hardinge Mills 0 02-19-2009 10:25 PM
R2E3 X-Axis problem Jadaan27 Bridgeport and Hardinge Mills 1 09-06-2007 07:18 PM
Z axis going nuts on my R2E3 Creative Tool Stepper Motors and Drives 1 06-08-2006 11:37 PM
