Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 01-03-2012, 12:54 PM
Interact77 is on a distinguished road
DX-32 flash disc drive $25 how to
I just purchased a 1996 Romi Powerpath 15 with the DX32 control. I did not get the system discs for this machine so i needed to back the hard drive up. This is how i did it.
Remove Hard drive from your machine and hook it up to a desktop computer. Use winimage to extract the data from your drive and save it to your computer.
Then use winimage and write it to a compact flash card....I used a 4GB sandisk extreme III.
Purchase a FB-4617 compact flash to IDE adapter for $25 from www.logicsupply.com and put it in place of your harddrive. you may need an adapter to be able to plug the power cable into it...about $2 from a computer store.
Machine works perfect
Hope this helps some people
Would be a good idea to save the harddrive image to a flash drive and burn it to a CD so you can put it in the control panel for safe keeping.
3 ½ floppy drive to USB flash drive readers scadvice General Electronics Discussion 8 08-10-2010 11:43 AM
USB flash drive issue extanker59 Haas Mills 13 05-17-2010 02:47 PM
Just IN- Acramatic Flash Drive Retrofit kit Jacob2000 Product Announcements & Manufacturer News 0 06-04-2009 02:33 PM
Newbie- demo / flash drive rsm169 NCPlot G-Code editor / backplotter 2 05-23-2008 05:46 AM
USB Flash Drive HelicopterJohn Haas Mills 30 11-23-2007 06:40 PM
