Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 12-20-2011, 11:52 AM
i_r_machinist is on a distinguished road
BMDC error, desktop? = $1100 ezpath bill
Two nights ago I got the bmdc error when booting the machine. It was a "error while reading c:drive".
I figured I would make a backup copy of the ezpath at work and write over the corrupted file on my machine.
It loaded but gives me a "Key not found or wrong key" when it boots up.
I call EMI and they tell me that the software is $140, but it doesn't work well with the old boards so I need to spent $1100 on an upgrade.
Anyone been down this road?
thanks
Kerry
Old 12-22-2011, 05:55 PM
WagonWheel is on a distinguished road
Sorry, no help with the errors.
I have two machines that I upgraded with the EMI replacement motherboards and DOM's (Disk on modules) and their software. They work well and seem a bit faster than the 486 boards and hard drive. I have another machine with the 486 motherboard and original software that will probably get the same upgrade some day. Something I learned back when personal computers started under CP/M and DOS; make a copy of original software before installing it for the first time. Some software once installed is then keyed to that machine. With a copy of the original software if a drive and motherboard has to be replaced the software can be reinstalled without problems.
If you can find a Dosasaur they might get you up and running with the copy you made.
Old 01-03-2012, 07:23 AM
Went with the EMI full package. Works great.
thanks
i_r_
Need Help!- anilam 1100 "keyboard error"? beneby General CNC (Mill and Lathe) Control Software (NC) 0 02-15-2011 08:55 PM
EzPath 1S Stops Error? zruss Bridgeport/Romi Lathes 0 03-03-2010 09:17 PM
Mechanical Desktop "Error - Incorrect Object To Bind - T" CNCOX Autodesk Software (Autocad, Inventor etc) 0 11-23-2009 04:45 PM
Strange Positioning Error - Anilam 1100 Randy Stevenson Controller & Computer Solutions 0 05-05-2008 11:01 AM
Ezpath Iiis Error Msg Zombiestomp General Metal Working Machines 1 10-27-2007 09:08 AM
