Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 06-06-2011, 10:56 AM
amgearinc's Avatar
amgearinc is on a distinguished road
Bridgeport Powerpath X axis problem
Once in a great while when we adjust the X wear offset on our Brigeport/Romi Powerpath the machine will increase the X position by about 6". It has done it 4 times in the last month. The wear offset was only changed by .0003" but when the tool would come in it was 6" above where it should have been. It is happening on multiple tool positions. I'm guessing that it has to be something in the control. When you look at the absolute position on the machine it has not changed, as far as the numbers anyway. Any suggestions would be welcome.
Thanks,
Greg Scott
American Gear, Inc.
Romi-Bridgeport PowerPath 15 users? RedGTZ Bridgeport and Hardinge Mills 41 10-04-2011 11:32 PM
Bridgeport Powerpath lathe turret spinning Larry Callahan General Metal Working Machines 1 02-10-2010 09:44 AM
Need Help!- Bridgeport powerpath 15 Nadda` Bridgeport and Hardinge Mills 2 01-06-2010 11:22 AM
Z-axis Problem Bridgeport CNC serie 1 Rufan Bridgeport and Hardinge Mills 5 08-09-2005 08:31 PM
How To; troubleshoot an Axis problem on Bridgeport BOSS inthedark Bridgeport and Hardinge Mills 0 03-25-2004 07:35 AM
