Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 03-10-2011, 09:56 AM
WagonWheel is on a distinguished road
EZ-Path II alter cabinet for headstock alignment
I decided to make some clearance holes in the cabinet sections to make it easier to get to the two front headstock bolts. Now the headstock can be aligned without having to remove the cabinets etc.
Name:	Ez-Path-II-left side 001.jpg‎
ID:	128620   Click image for larger version
ID:	128621   Click image for larger version
ID:	128622   Click image for larger version
Old 11-16-2011, 11:14 AM
Helix22 is on a distinguished road
Awesome modification !!! I have an EZ PATH SD and it needs another allignment after a crash. I dread taking that cover off and doing the adjustment. I cant take the cover completely off because of the CRT and keypad and have to prop it up with wood blocks and reach in there. Last time it took a few hours. The only thing I might do different is make a custom gasket to keep out coolant. Thanks
Old 12-13-2011, 11:07 AM
stephenmtate is on a distinguished road
Can I ask where you got your test bad from?
I have a EZ Path II 20" with a 65mm through hold. The manual give a 1 degree 25' 55" taper but no Morris taper equal like it does for the tail stock.
Thanks in advance.
Steve
Old 12-22-2011, 06:04 PM
Thanks! I did make a gasket for the opening on the left facing the chuck. The piece on the right has a ship lap type fastening. If some coolant would get behind behind the vertical joint it would just drain easily.
Need Help!- How to alter #1000 variables hydrospin01 Fanuc 4 01-05-2011 01:35 AM
MT1 into taig headstock chris123 Taig Mills & Lathes 0 10-19-2010 06:16 AM
why does mach3 alter my gcode? turbothis Mach Software (ArtSoft software) 4 10-17-2010 05:08 PM
9x20 Headstock alignment pics ZipSnipe Mini Lathe 1 06-05-2009 08:49 PM
LB-15 Headstock alignment nlh Okuma 9 05-22-2009 08:34 AM
