Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Bridgeport/Romi Lathes
Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here!
Old 09-17-2010, 04:28 PM
elsie215 is on a distinguished road
Bridgeport EZ Path
We moved this lathe and can not get the computer started. We turn on and ge the message waiting for DOS. We have a later Bridgeport. Info in the later Manual says to hold Control, Alt, Delete. Any one know if this is the way to start DOS in the EZ Path.
Thanks,
EC
Old 09-18-2010, 05:27 AM
bret4 is on a distinguished road
What I would do is reload the machine using the original floppy disc that came with the machine. With the machine off put the disc in the floppy drive. Turn the machine on and follow the on screen instructions to reload the software. If that doesn't work then something bigger may be wrong.
Old 09-18-2010, 02:46 PM
Bridgeport EZ Path
Bret
Thanks for the reply. We used the backup disk but keep getting the message waiting for DOS. I'll try the BPT guys Monday if I don't get anymore replies.
Old 09-18-2010, 04:03 PM
If you have checked all the plugs that plug into the pc parts in the back, then it could be the drive went bad. I seem to remember that the old ones may have come with a standard hard disc drive. The newer ones came with a flash memory drive because the hold up better. Any way you look at it your drive may be bad or the cable is just loose. If not the bridgeport guy may need to fix it.
Old 09-18-2010, 07:03 PM
WagonWheel is on a distinguished road
Control Alt Delete is the software equivalent of pressing the reset button or turning the machine off then on. It just reboots the machine and does not normally get to a DOS prompt on the EZ-Path.
I have a PowerPath and an Ez-Path II. When the machine is started the first screen should stay there for a couple of seconds allowing for the Delete key to be pressed to enter the BIOS. After that a screen should come up and on that screen it should say starting MsDos somewhere. It should then say “opening BMDC.bin” These go by quickly so may take restarting a couple of times to see them. If you see these messages then the autoexec.bat program is executing on C:\. On my Ez-Path II the autoexec.bat program then switches directories to the C:\EzPath directory and executes the EZ.bat batch program etc.
If you see the above messages if should mean the hard drive is physically OK so that could be eliminated. As bret4 said, it would have been nice if the backup disk would have reinstalled the software; and hopefully preserved the existing parameters.
Old 09-19-2010, 03:16 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I moved my miller and had a similar problem booting from the floppy... turns out the boot disk was partialy ejected- the enclosure door was pressing against the eject button just enough to partialy eject the disk when the door was closed, when you opened the door it re-seated itself. Took me a whole day to find this out!
Just a thought
I love deadlines- I like the whooshing sound they make as they fly by.
Old 11-09-2010, 09:13 PM
DLBEE is on a distinguished road
no boot disk
We have a '95 Bridgeport ez path lathe that acts like the hard drive is not working. The screen message ask to insert the boot disk, which was not received when we purchased the machine. Is there anywhere to get a boot disk for this machine? Any good repair mechanics for these machines?
thanks,
David
Old 12-16-2010, 10:29 AM
JoBwan's Avatar
JoBwan is on a distinguished road
DLBEE,
Try DB - 2 from Warren, Mi.
Just a good ol' boy, never meanin' no harm.
Joe
Old 01-07-2011, 03:04 PM
gdwood3rd is on a distinguished road
Call Quantum Machine, certified B'port Service, 303-503-9677, they are great to deal with
bridgeport ez path lathe sempe0 Want To Buy...Need help! 0 03-11-2010 11:01 AM
Bridgeport EZ-Path motherboard stein530 Bridgeport and Hardinge Mills 1 07-30-2009 07:56 AM
Need Help!- Bridgeport Power Path elsie215 Bridgeport and Hardinge Mills 0 06-18-2009 02:11 PM
Problem- Bridgeport lathe cnc ez path J Hailmann Bridgeport and Hardinge Mills 6 06-04-2009 06:27 PM
EZ Path Bridgeport lathe ruger2 General CNC (Mill and Lathe) Control Software (NC) 1 05-31-2007 01:33 PM
