| Bridgeport/Romi Lathes Discuss Bridgeport/Romi Lathes here! |
Hello, I'm having trouble with my bridgeport ez-path series 1 lathe. The emergency stop error message keeps flashing up on the screen, with hit (key) to clear. And wont clear. I can bypass this message by manually pushing the button in on the 24v relay and then the message clears. hovever,, when you go to home the machine the slideway comes past the limit switch then comes back. Then the screen will come up with.... following error limit exceeded. The bmdc card is comunicating with the auf board and all the drives work manually. Its just strange why the relay wont come on on its own. any help would be great. thanks Dave |
| This machine has 2 E-stop switches. One on the CRT pendent and one on the carraige. the one on the carraige suffers from coolant contamination. The box the E-stop switch is in has a connector on the back. Check it for corrosion. Then there is the possibility that the cable coming from the control through the flexible wireway to the carraige can break from flexing and age. George
| Bridgeport/ROMI EZ Path Lathe | mcsf | General Metal Working Machines | 3 | 12-13-2010 07:55 PM |
| Need Help!- Bridgeport EZ path romi lathe | dipiazza | General Metal Working Machines | 0 | 12-04-2008 09:48 PM |
| Need HELP on Bridgeport EZ-Path ROMI Lathe | Michael Esch | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 04-09-2007 10:38 PM |
| Romi EZ Path Lathe | kenski | General Metal Working Machines | 2 | 07-21-2006 09:25 PM |
| Manual needed to Romi/Bridgeport CNC lathe | mgreene | Bridgeport and Hardinge Mills | 2 | 02-15-2005 02:20 PM |
