Results 1 to 2 of 2
Thread: No low spindle speed
    Mar 2010
    Help, I have a 1994 16 x 40 Bridgeport Romi EZ Path lathe. I ust got it wired up and cannot get it in the low speed, also the jog button doesn't work.
    Any thought on where to trouble shoot this problem?
    Thanks Shoeman
    Sep 2008
    HI/LOW handle?
    Do you have a HI/LOW gear handle
    if you do... it could be a prox switch not making. there are 2 switches, under the guarding, on the outside of the head that the gear changer uses to tell the system if it is in low or high gear.
    you'll need to pull the guarding off the head of the lathe to check these switches. bit of a job but not too bad. (25 or 30 button heads)
    on mine, the prox switches are mounted to small angle brackets that had the mounting bolts come loose. i used locktite on the bolts to prevent it from happening again
    i'm not sure about the jog button - i'm sure someone else will know
    good luck
    Mac
  1. What is the best spindle speed....
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 11-30-2008, 08:31 AM
  2. IH Spindle Speed?
    By SCzEngrgGroup in forum Industrial Hobbies (Support forum)
    Last Post: 10-22-2007, 09:26 PM
  3. Spindle speed not 100%
    By AndyB in forum Fadal
    Last Post: 07-13-2007, 09:52 PM
  4. spindle speed
    By Mike Boarman in forum Machines running Mach Software
    Last Post: 11-27-2006, 10:37 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport and Hardinge Mills
    Last Post: 08-08-2006, 04:29 AM
