Old 02-22-2010, 06:41 AM
Krefte is on a distinguished road
Bridgeport VMC 3020 constantly using air
Hello I have a bridgeport VMC 3020 with a fanuc 21i control.
I am having an issue where air usage is constant. I can feel air coming from around the spindle making me think that there may be a stuck valve or bad gasket. I have the maintenance guide but am still having trouble finding where the air leak could be coming from.
I would like to find this as it is making my air compressor run all the time and I fear the compressor won't hold up if I leave an already proven program running over night.
Thanks for any help/advice. - Ed
Old 02-22-2010, 07:57 AM
Moderator
machintek is on a distinguished road
Yes there is air constantly running out from around the spindle and it was designed that way. It should be set at about 15 PSI. This is to protect the spindle bearings from trash getting in there. It should have a air shut off where it comes into the machine.
George
Old 02-22-2010, 08:02 AM
Thank you for the quick response.
One more question though how much air should be coming from the bleeder which is next to the air input? It seems like a high amount as I said our compressor runs almost constantly. Maybe it is that I don't have a large enough compressor though also.
Old 02-22-2010, 08:24 AM
mactec54 is on a distinguished road
Krefte
George said how much should be coming out, you should have it set to 15psi, & your compressor would need to be at the smallest around 60gal tank 13cfm, the bigger the tank the better, then the compressor won't be running all the time
Mactec54
Old 02-22-2010, 10:05 PM
Moderator
Is the bleeder at the bottom of the plastic bowl? If so and it is leaking, it is defective.
If it is of the automatic type, it will drain when enough water is in it, if it is the manual type, it should not leak unless it is opened manually.
George
Need Help!- Fadal 3020 Siemens Tool reset egw Fadal 2 04-15-2009 02:45 PM
Need Help!- fadal vmc 3020 spindle error matosjulio Fadal 2 02-11-2009 01:20 PM
Problem- VF-3 pcool constantly homing horst007 Haas Mills 4 05-02-2008 09:27 PM
Fadal VMC 3020 Advice Bugster Fadal 1 11-13-2006 01:59 PM
